  • 1994 - 1995 Specific Tech
Summit vs. Mishimoto
  • Thread starter Thread starter Yobi1Kanobi
  • Start date Start date Jan 18, 2008
Summit Radiator or Mishimoto
  • Summit
    Votes: 3 20.0%
  • Mishimoto
    Votes: 12 80.0%
  • Total voters
    15
1 of 2 Next Last
Yobi1Kanobi
559
  • Jan 18, 2008
Pretty much I need to decide between a summit universal fit or the mishimoto. Any comments or complains are welcomed.
Thanks
Venom351R
4,548
41
98
MAINE
Jan 18, 2008
  • Jan 18, 2008
whats the price difference on the two? I found a place that ships the Mishimoto for $189
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jan 18, 2008
  • Jan 18, 2008
The Summit universal radiator requires welding some brackets on to get it installed correctly. I don't know if you remember Jason (mytight95) and when he had one, but it was done on the cheap. Unfortunately, the pics are gone, but I found the original thread from 2006, if it might give you some pointers, plus a couple other related threads:
http://forums.stangnet.com/showthread.php?t=635551
http://forums.stangnet.com/showthread.php?t=632581
http://forums.stangnet.com/showthread.php?t=632107
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Jan 18, 2008
  • Jan 18, 2008
I've got the Mishimoto, and so far I've had no problems. It's a very nicely made piece, and went right in with no modifications. I was running at 210*+ whether it be 30* outside or 90*. After installing the rad, a 180* stat, and a low speed manual fan switch, it runs at 180* without the fans in cooler whether (60* and below), and 190*ish on hot days with the fans turned on intermittently. It cost me $10 for the thermostat and $10 for the switch, a fuse, and some wire, and if you haven't already done these mods, do them at the time of radiator install and it will make a huge difference.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Jan 18, 2008
  • Jan 18, 2008
statracing.com?? thasts who I found for that price shipped.
Pokageek
2,767
MA, USA
Jan 19, 2008
  • Jan 19, 2008
I have had zero problems withmy summit universal! It was inexpensive and fits very well after a couple of slight mods to the install!! (and I am picky)
"whats the price difference on the two? I found a place that ships the Mishimoto for $189"
Be careful there. I have always found if the price is waay different, you are lucky to get it or have all kinds of trouble with the $$ transaction.
Dino Dino Bambino
1,672
89
79
Cyprus
Jan 19, 2008
  • Jan 19, 2008
I'm very happy with the performance of my Mishimoto, and I think it looks great under the hood too.
Yobi1Kanobi
559
  • Jan 19, 2008
I might go with the mishi if I can take off the Mishomoto Plate....I dont wanna have to explain the radaitorr every time i opwn the hood
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Jan 19, 2008
  • Jan 19, 2008
i would go with the misho since its drop in, no mods needed
i had to trim my fan shroud a lil to get it to fit on the summit rad. to get it in the car was pretty simple, just had some hooks bent up similar to how the fox radiators are held in and used the stock rubber lower mounts
Venom351R
4,548
41
98
MAINE
Jan 19, 2008
#10
  • Jan 19, 2008
  • #10
Pokageek said:
I have had zero problems withmy summit universal!* It was inexpensive and fits very well after a couple of slight mods to the install!!* (and I am picky)"whats the price difference on the two? I found a place that ships the* Mishimoto for $189"Be careful there.* I have always found if the price is waay different, you are lucky to get it or have all kinds of trouble with the $$ transaction.
Yes Statracing.com
Pokageek
2,767
MA, USA
Jan 19, 2008
#11
  • Jan 19, 2008
  • #11
Never heard of them. Just looked onthe net and the prices are much closer now. What that the one everyone was having trouble with leaking? I thought they were $400...or was that another radiator brand?
Dino Dino Bambino
1,672
89
79
Cyprus
Jan 20, 2008
#12
  • Jan 20, 2008
  • #12
That's the $400 Fluidyne that you're referring to.
SVTtripleblack
166
Lancaster, PA
Jan 20, 2008
#13
  • Jan 20, 2008
  • #13
I just installed a Mishimoto this weekend due to a small leak in my stock rad. I payed around $200 for it shipped. The Mishimoto fits perfectly and seems like it is very good quality. It took a little longer than most people say to install which is about 2 hours. It took me about 3 hrs. because I take my time and this was my first rad install. So far so good. It runs a little cooler than the stock rad. I would say go with the Mishimoto because it doesn't require any mods to fit.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Jan 20, 2008
#14
  • Jan 20, 2008
  • #14
It stays covered with the plastic cover if you still have it.
Yobi1Kanobi
559
#15
  • Jan 20, 2008
  • #15
Not really
SVTtripleblack
166
Lancaster, PA
Jan 21, 2008
#16
  • Jan 21, 2008
  • #16
Yeah, if you're really worried about people seeing it, just order another plastic cover if you don't have your original. The only thing you can see on my car with the plastic cover on that says Mishimoto is the radiator cap. And if you want you can get a new 16lb cap from napa or autozone for under $10 and no one will ever know. I could care less what people say. If they think none of the wiring or sensors that came factory on Mustangs isn't from Japan they are probably very wrong. As long as it does its' job don't worry about where it's from.
94-302-vert
1,947
NE CT
Jan 21, 2008
#17
  • Jan 21, 2008
  • #17
I have to say that my mishimoto radiator died. I hit a pothole that really bottomed the car out, and the braze joint at 5 of the fins cracked. No damage to the radiator other than this. Since this would not be covered under warranty I am uncertain if I am going to go with another mishimoto or not.
The fit on my car was not that good (pass side was a tight fit at the bottom, this could have helped to cause it to fail)... So I am not sure what I am going to do but my stocker leaks when it is cold out and doesn't cool well when it is hot out.
S351Saleen77
423
Washington
Jan 21, 2008
#18
  • Jan 21, 2008
  • #18
Can't you have this repaired? Is it leaking?
Anyway sorry to hear this. You were in on the group buy right?
I have compared the Mishimoto side by side to a Fluidyne and the quailty is right there, plus there seems to be too many Fluidyne's leaking on this forum....and they cost 2 times as much!!
Not sure why you had a fitment issue....has your car ever been in a front end collision?
F
fordtech28
312
Riverside Cali.
Jan 21, 2008
#19
  • Jan 21, 2008
  • #19
I bought the universal Summit one for 160 and it only cost 3 dollars for the mounts to get it on there from home depot .And it holds more water than the Mishimoto radiator and the fluidyne.I had the fluidyne and it started to leak after 3 years I was more inpress with the summit one the welding and the quality of the work they put into it and from my experience the summit radiator has kept my car cooler than the fluidyne did and since the Mishimoto is the same design I was hesitant to get it due to the fluidyne leaking .
S351Saleen77
423
Washington
Jan 21, 2008
#20
  • Jan 21, 2008
  • #20
StangGT1995- This one was very good, Thanks!! I really learned something about how the new coolant coats the tubes of a new rad and looses alot of what it needs.
http://www.imcool.com/articles/antifreeze-coolant/whygoodradsgobad.php
1 of 2 Next Last
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
M
1966 289 Electronic Ignition
  • MrStangBoise
  • Jan 18, 2025
2K
1965 - 1973 Classic Mustangs -General/Talk- Jan 23, 2025
Realmongo
G
Fox Tire Size for 16" Pony Wheels on 1984 LX Convertible
  • gw7
  • Jun 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 25, 2026
Qtrhrse23
