Sunroof gasket
StangII78
41
Gray, GA
Anyone know where I can find a replacement sunroof gasket for a 78 Ghia? The previous owner has silicon-ed the sunroof shut. I guess the gasket was leaking and instead of fixing it he opted to just seal it. I however want to use it. Thanks for any help.
Kevin
Well, today I cut the man made seal that was preventing my sunroof from opening and found that the seal does not leak. I did find that the rear drain hose is leaking and will be an easy fix. Now, I need the felt gasket that fills the gap between the glass and roof of the car. Is there a replacement for this or can I use one from a 79 on Mustang? Thanks
Kevin
I came up with a solution since no-one on this planet makes anything for this car. I decided to use a universal trunk gasket from Advance Auto Parts. To my amazement, It fit perfectly and solved the problem I was trying to correct. Now, on to the next pain in the Astrix.
