  • 1994 - 1995 Specific Tech
Sup NOS guy's?
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date May 12, 2005
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 12, 2005
  • May 12, 2005
K i'm bout to install a 100shot wet edelbrock on the stang. so i have the 255 pump what else do i want to do? i'm putting on a set of stock worked over heads and a trick flo street heat with 3/8 spacer as well at the same time. i already have the E303 cam installed. i am also going to go with a SCT chip as well as a crane box that automaticaly retards and so forth in a couple weeks. Next week will be the bassani's ceramic header's to replace the cheap ass flo tech's. So give me a run down on thing's i also need to do to run safe besides the pump? plugs? injector's? timming? if so what degrese? anything else? My current mods installed is a E303 cam, mac cold air, prof. products 70mm T.B, 76mm C&L MAF, areomotive adj. fuel reg. set at 45PSI., bassani O/R X-pipe, flow master american thunder 3 1/2" tip's, ASP alum. pullies, timing at 12. Waiting to install with the bottle is a T.F street heat with 3/8 spacer stock heads from an 87-93 with dual springs 194 valves (i beleive) ported polished, valve guides releived, comp roller rocker's, ARP head bolts, SCE head gasket's. Help me out i dont want to blow!!!! How big of shot on the stock bottom end? I've heard these hyperstathic pistons dont like power adder's? One more thing my best time minus the T.B is 13.993 what do you think i can get from the heads intake and the 100 shot? Low 12's????? peace
john
I
IM_FASTER_THAN_
56
GREAT STATE OF OKLAHOMA
May 12, 2005
  • May 12, 2005
It all depends on how good of a driver you are. I know several ppl that take a bone stock car, and add nitrious and run 12's so you should be in the 12 for sure. You just have to be able to drive the car right to take it to that time
N
Nobody
2,515
Kenmore, WA
May 12, 2005
  • May 12, 2005
You seem pretty concerned about blowing it up. Therefore, get a window switch and a FP safety switch. Set your window switch to activate at 3,000rpm and de-activate before your fuel cut-off (6250rpm is stock) 6,000 is standard
Make sure you use the WOT switch and don't use a button to spray.
Set your timing to 8 degrees base.
Use octane booster (just to be safe) when you go to the track.
Keep the engine cool.
That's all that I can think of so far.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 12, 2005
  • May 12, 2005
not to concerned BUT DONT WANT TO! it's got the WOT switch and the fuel switch. i run 92 oct all the time thats the highest we can get out here. My main concern is the pistons in these engines , i heard they dont like power adder's? Thanks. pace
john
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • dan50
  • Jul 18, 2026
dan50
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Forced Induction Total Timing under boost
  • Dontknowchit
  • Aug 27, 2025
Fox 5.0 Mustang Tech Aug 28, 2025
Dontknowchit
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
