Supercharged PCV woes
  • Thread starter Thread starter 7-UP BILL
  • Start date Start date Apr 28, 2006
7-UP BILL
885
My other car is a Firetruck
Apr 28, 2006
  • Apr 28, 2006
Has anybody had problems in supercharged application of blowing the PCV out of its hole, grommet and all. Any remedies? Causes? Thx for all answers.
L
luckythirteen13
648
Anaheim, CA
Apr 28, 2006
  • Apr 28, 2006
do you have that line hooked up that runs from the tb to valve covers? if so, you have to get rid of that because it would send boost pressure into areas you dont want it
7-UP BILL
885
Apr 30, 2006
  • Apr 30, 2006
That line is disconnected. Anyone else?
L
luckythirteen13
648
Anaheim, CA
Apr 30, 2006
  • Apr 30, 2006
is the pcv working as a check valve properly? i pulled mine out the other day to replace the worn hose that was on it and put on an oil separator. the hose was leaking but i checked to make sure the pcv was working. if its letting air into the engine then of course it will blow out.
7-UP BILL
885
May 1, 2006
  • May 1, 2006
I changed to a SVO PCV on the recommendation of a highly knowledgable Mustang /Ford Technician. This was done about 8-10 years ago. never gave it any thought again. He said it would alleviate added block pressures associated with a turbo/blower application. I checked it the other day after taking the car out of winter storage, that's when I noticed the grommet out of it's hole. BTW, PCV is working fine. Sprayed with carb cleaner, good as new. Any more thoughts?
358stroker
62
Austin, TX
May 1, 2006
  • May 1, 2006
Are you venting your valve covers at all?
7-UP BILL
885
May 3, 2006
  • May 3, 2006
I did have the FMS breather cap on. I removed it when I found the PCV out. Wouldn't this have vented the crankcase pressure?
A
Aaron'S'tang
58
Lake Geneva, WI
May 3, 2006
  • May 3, 2006
Breather
358stroker
62
Austin, TX
May 5, 2006
  • May 5, 2006
the PCV isn't meant to handle much pressure, that's why it's blowing out. I have a breather run 9lbs of boost and have never blown out my PCV.
L
luckythirteen13
648
Anaheim, CA
May 5, 2006
#10
  • May 5, 2006
  • #10
i run my pcv with a breather and havent had any problems but i recently was told i should be running a breather on each valve cover
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Engine Belt routing with supercharger and smog/ac/ps delete
  • Steve6482
  • Jul 15, 2026
Fox 5.0 Mustang Tech Jul 15, 2026
Steve6482
9
Unknown engine tick
  • 94 Daily
  • Oct 31, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 1, 2025
91AOD5.0LX
