  • SN95 4.6L Mustang Tech
supercharger 4.6 GT???
  • Thread starter Thread starter boostedpony
  • Start date Start date Aug 26, 2004
First Prev 2 of 2
showstopper2
425
New Bedford, Ma.
Aug 29, 2004
#21
  • Aug 29, 2004
  • #21
I would recommend a Procharger P1SC-2 with the three core cooler. there are no more seal issues with these blowers that I know of. Older kits had the problem. I currently have this on my car and make over 400rwhp and 400rwtq all day on the dyno with nothing more than a TFS plenum, Accufab 75mm, Pro-m ATI solutions meter, 42lb injectors, Aviator pump, and a SLP catback. I was going to buy a D1 kit until I saw a similar car to mine in mods make 415hp and only 360tq on the dyno. the D1 is too lazy a blower for a stock motor. you need to rev the motor much higher with that blower to make it worth while.
I am still running stock headers, catalytic pipe, stock POS ATI blower inlet and a completely stock 04 engine.
just for comparison to the KB guys I paid a little over 5K for all the motor parts and the blower kit. I was going to get a KB but they want 5K just for the blower and then I would still need the injectors, TB, and inlet kit.
BrightBlue00GT
I am even OLDER than Hawk!
Jun 22, 2000
2,906
Stationed in Korea
Aug 29, 2004
#22
  • Aug 29, 2004
  • #22
You didn't look close enough then, because the KB for $4900 comes complete and should make the same 400hp as you have, but more torque with the stock motor, TB and inlet tube. The 9# kit includes:
• Billet Twin Screw 1700 Supercharger
• Hi-Flo CAst Inlet Manifold
• Billet Bypass Valve Assembly
• Bar and Plate Intercooler, HD Heat Exchanger, Intercooler Pump and Water Fill Reservoir
• Re-calibrated Mono Chip
• 36lb Injectors
• BOOST-A-PUMP™
• Fuel Rails
• 160° Calibrated Thermostat
2000BLKGT
361
Toronto
Aug 29, 2004
#23
  • Aug 29, 2004
  • #23
Another vote for the KB here.
One of the biggest benefits is that plastic excuse for a stock intake manifold is gonzo with the KB kit. So although the kit may seem expensive versus the competition...the competition doesn't include a new intake manifold with there's. (go price out an aftermarket intake manifold...all 3 of them) Not to mention the kit is totally complete..injectors, fuel rails etc etc.
The hp gains are comparable or better than other kits running similar boost.
And the KB tq curve just kicks a$$.
Finally...you want shock factor...order the KB polished...its a freakin peice of jewelry.
Go to www.kennebell.net read everything on the site...compare that with the info shared on all the other blower brand sites...the Kenne Bell sells itself.
Do your research...the KB design is comparable to the lungs installed on the Ford GT, the '03+ Cobra...and all the blown Benzs...there's a reason why this style was chosen.
onesticker
222
Jacksonville,FL
Aug 29, 2004
#24
  • Aug 29, 2004
  • #24
KB....maybe one day I will have one. I can't complain about my Vortech though.
2001_GT
Lone Tree Colorado
Aug 29, 2004
#25
  • Aug 29, 2004
  • #25
I have a ProCharger P1SC with a 3-core intercooler. If I had it to do over again, I'd go with the Novi 2000. If you go with the P1SC, however, invest in the Snow Performance boost cooler. A reputable installer can tap into your windshield wiper resevoir (cheap washer fluid is 50% methanol). This way you can put timing back into the car safely. And as you know, timing means POWER. Email me if you have any other questions. I'll gladly help.
1992 2.3LX
885
Ky
Aug 29, 2004
#26
  • Aug 29, 2004
  • #26
if you go with the KB on a 96-98 can you keep your strut tower brace with the stock hood.
that would be a big issue since i have a vert.
2000BLKGT
361
Toronto
Aug 29, 2004
#27
  • Aug 29, 2004
  • #27
I doubt it. A buddy of mine up here was talking about getting a custom STB fabbed up for his '99 coupe...he was running one before his install.
The supports running from the firewall to the strut towers is a no-brainer...but coming up with the cross member looks like a needle in a haystack...it's real busy in front of the lung.
First Prev 2 of 2
WTB: Procharger or Vortech Supercharger – 1996–1998 Mustang GT 4.6 2V – Budget $3,200
  • 96mustang.gt
  • Nov 20, 2025
  • Want to Buy
Want to Buy May 3, 2026
roblabsn95
R
D
4.6 DOHC build.
  • Diffydoc
  • Oct 11, 2025
  • Other Auto Tech
Other Auto Tech Oct 11, 2025
General karthief
C
Paxton novi 1200SL
  • Cambo617
  • Oct 9, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 9, 2025
Cambo617
C
D
How to test for a bad coil pack - 4.6 liter motor
  • DesertStang
  • Oct 7, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 14, 2026
DesertStang
D
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
