Supercharger From 95 onto 92
_Cheese_
22
Found A 95 5.0L mustang with a S/C in the wreckers, they want $1200 for it. I pull. I plan on putting this on the '92 5.0L.
What will cause me problems with installing this.
What should grab from the oblivious. Pullys, belts, s/c, piping, bracket, oil lines, injectors, reg,....
And for timing, what should it be set at with the spout connector unplugged. Im guessing this would be a 6psi kit. Gas octane?91, 93
What brand is it, before we even decide if it's worth buying? You'll need the bracket, intake assembly, discharge assembly, water pump and crank pulleys that I can think of off the top of my head. You'll be well over $1,200 in parts you'll need to buy. Then you'll want to add a bigger fuel pump and injectors to the car, so you don't lean out. Here's a complete S-trim kit for a Fox for $1,500: link
