supercharger knocking noise????
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
i installed my new RR pulley and IC setup. i test started the car to make sure there were no leaks or anything and the s/c is making a clicking/knocking noise. is the pulley on wrong? is is spinning good, no wobble from side to side or anything. i reconnected all the oil lines and everything. someone please help me find out what is going on.
i know that it is getting oil to the supercharger. how can a pulley make a noise like that? could the tensioner be going bad? do i need a shorter belt when swapping from a 3.5 to a 3.4 pulley? i'm about to just sell the whole IC setup and be done with it!
ok i think i found the problem. the edge of the RR pulley is just barely hitting the idler pulley under it. i can see a line on the idler from the Rs/c pulley riding on it. is there anything i can do to fix this?
RR? Does that mean Reichard Racing?
Anyways, is it hitting the idler that is on the swing arm of the tensioner? Maybe the spring in the tensioner is weak and needs replaced?
yes it is a reichard racing ultra grip pulley and no, it isnt hitting the pulley on the tensioner. it is hitting the idler pulley that is just above the tensioner. maybe MPH will get me a new paxton pulleyt since the RR one is not working. i could get my friend to mill the edge down a little but i hate to start cutting on a $150 pulley! for that price it should work perfectly. oh well i guess i will have to tear it all down again and start from scratch tomorrow evening
