I just recieved my car back from the shop. I just got a ATI Procharger put on it. The 8 PSI with the intercooler. I have a couple of questions. First Question is do you have to get a different fuel pump with 42LB/Hour injectors? Also my car seems like it is not getting enough fuel and it will cut out in 4th gear when it hits about 5,000RPM..Do you think that would be the fuel pump or the chip? Plus the chip is a diablo sport predator chip. I have heard many bad things about these chips. A little help would be appreciated because I can not figure out the problem. Also I am not getting the full 8PSI of boost, I am only hitting 5PSI.
