supercharger
  • Thread starter Thread starter 357stroker
  • Start date Start date Nov 22, 2009
357stroker
  • Nov 22, 2009
im looking for a supercharger for my mustang i have a 1990 with a 351 what is there that is a decent supercharger and how much hp would i gain
1991notchbackLX
1,483
47
48
New York
Nov 22, 2009
  • Nov 22, 2009
what is the meaning of life?
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Nov 22, 2009
  • Nov 22, 2009
where does the blue grass grow?
Repostyle
538
Portland, OR
Nov 22, 2009
  • Nov 22, 2009
If a tree falls in the woods and there's nobody around to hear it....
Your question is unanswerable. There are a lot of superchargers out there and some are better than others for a spacific setup, but there is no right answer. Same goes for HP gains.
1991notchbackLX
1,483
47
48
New York
Nov 22, 2009
  • Nov 22, 2009
translation: i have this thing, i'd like to get another thing for it... what exact kind of thing should i get for my thing, and how many things will i gain from adding the thing you suggested?
give us some info on your motor and vehicle so we can better help you out
357stroker
  • Nov 22, 2009
i have a 1990 mustang lx with a 357 it had the eldebrock rpm heads trick flow heat and track upper and lower intake 11 :1 compression 70 mm throttle boddy
9
94gtfreak
412
your moms house
Nov 22, 2009
  • Nov 22, 2009
Why not turbo??
357stroker
  • Nov 22, 2009
what is really the difference between turbo and superchargers
1991notchbackLX
1,483
47
48
New York
Nov 22, 2009
  • Nov 22, 2009
research
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Nov 22, 2009
#10
  • Nov 22, 2009
  • #10
one mounts outside of the car the other mounts in the cab
bentley429isBAC
922
188
84
CT
Nov 22, 2009
#11
  • Nov 22, 2009
  • #11
11:1 compression for a supercharger? Are you planning on running 1.3984 psi? 70mm throttle body????
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Nov 22, 2009
#12
  • Nov 22, 2009
  • #12
This is the fastest derailing I've seen in a while...
Supercharger is basically a belt driven turbo
turbo is a turbine driven by exhaust gasses with a compressor wheel which creates boost
Google is your friend
get a novi 2000 and call it a day
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Nov 22, 2009
#13
  • Nov 22, 2009
  • #13
i thought a super charger was something dodge made ?
nick6690
147
McDonough, GA
Nov 22, 2009
#14
  • Nov 22, 2009
  • #14
with 11:1 compression i wouldn't plan on boosting, that is way too much compression unless you want to run race gas.
S&B
I hate my CT. :(
1,634
695
204
Cheesehead
Nov 22, 2009
#15
  • Nov 22, 2009
  • #15
unless you directly injected ketup before the turbo....
beyondspexj
265
Las Vegas
Nov 22, 2009
#16
  • Nov 22, 2009
  • #16
lmao!!
with 11:1.... forced induction shouldnt even be a thought..
fiveohwblow
Official Member
2,169
145
155
Nov 23, 2009
#17
  • Nov 23, 2009
  • #17
Wait for it.... wait for it....
BANG
rbonella
409
@ home
Nov 23, 2009
#18
  • Nov 23, 2009
  • #18
I have a 357 windsor with 10.5:1 compression and boost is really not an option for me nor you unless (like mentioned above) you run race gas all the time. Boost meaning no turbos or superchargers. You might want to consider adding nitrous to you motor if you're looking for a lot more power
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
F
86 notch NEED HELP!!!!
  • foxbody86
  • Jul 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
What is this Ground Wire for?
  • TonyMano
  • Feb 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 14, 2026
Praetorious
P
