Supercharging!!!????
  • Thread starter Thread starter IICrazy
  • Start date Start date Aug 14, 2004
IICrazy
taken away
Mar 28, 2003
976
Maple Valley, Washington
Aug 14, 2004
  • Aug 14, 2004
Is there any cheaper alternative to go to rather than the paxton supercharger. That is the only one I can find for a carbed 302. any help is appreciated.
joeythesaint
402
Seattle
Aug 14, 2004
  • Aug 14, 2004
I've been looking at that same option. Hot rodders, correct if I'm wrong, here, but I'm told that if you supercharge a 302 with a 6:71 series (or bigger) impeller, you'll just "drown" it -- there's not enough air going out to compensate for the air going in.
This is why I'm opting to go with dual 500cfm carbs -- 1000cfm (1000cfm wide open -- 2, 500cfm 4bbls on a progressive linkage) should be plenty; my understanding is that it'll likely be too much without headers. The engine has got to breathe at both ends.
In the meantime, I'm measuring and penciling, trying to imagineer a way to stuff a big-block -- ideally a hemi, which responds spectacularly well to supercharging -- into my II someday.
email me at joeythesaint@comcast.net . It looks like we're going in the same direction; I'm all for comparing notes.
Power Surge
1,516
Palm Coast, FL
Aug 14, 2004
  • Aug 14, 2004
First of all, "cheap" and "supercharger" are not two words that usually go together. If you are not willing to spend what most blowers cost new, look for a decent used kit. You can use any centrifugal blower you want, all you need is the carb box to make it work.
You also can't just slap a blower on any motor. First, it must be healthy. You can put about 6 psi into a healthy stock 302. Second, you need to keep the compression under 9:1 or you won't really be able to use pump gas. If you want to make big power, you should build a blower motor, with fogred pistons, larger ring gaps, and decent flowing heads.
On my brothers pro 74, we just put his new setup in. It's a stock 92 5.0 (we'll build a 347 next winter) with an 8-71 on top. It will make about 5-6 psi. The car previously had dual quads, and ran like crap with them. Dual quads are too much for a stock/mild 302. Using the blower is different, because you are FORCING the air into the motor.
IICrazy
taken away
Mar 28, 2003
976
Aug 14, 2004
  • Aug 14, 2004
Thanks for the info. I have a 331 stroker kit that I want to build onto a stronger motor, As soon as I find a donor 5.0.
joeythesaint
402
Seattle
Aug 14, 2004
  • Aug 14, 2004
What size quads was he running, and how were they linked? I've read of impressive results with baby quads -- 500's -- on 302's and 5.0's. I can see twin 750's being too much. I'm not debating you; I really want to know before I get too far into this project.
Power Surge
1,516
Palm Coast, FL
Aug 14, 2004
  • Aug 14, 2004
Hey was running dual 450s. It's was too much for a stock/mild 302. We wound up disconnecting the secondaries and then the car was much better. I think Dano reported that his dual quad setup was a PITA as well, maybe he'll chime in too.
perce111
632
Bellingham, WA
Aug 15, 2004
  • Aug 15, 2004
Back to blowers
A real nice set up is the B&M [now Holley] unit
that they make for the SB Ford. Still must keep
8 or 9:1 compression.
I think from past experience it's not the size [dual 450s]
that is the problem it's multiple carburation that is tough
to syncronize.
Way back we built a tri carb unit for a hemi that ran
3 450 4bbl carbs modified. Talk about a pain to set up LOL.
Later
jeffnoel
1,638
Clovis, CA
Aug 15, 2004
  • Aug 15, 2004
If 3 2-bbls are a pain, I guess I scrap my 4 Webers idea, lol.
parthos
529
Bismarck ND
Aug 15, 2004
  • Aug 15, 2004
a key issue to keep in mind is pulley depth. I've a few different setups on other 302s, and 5.0s, and what is kinda scary is the pulley on the crank, it's pretty long.
Mstng2
789
- - Zion - -
Aug 16, 2004
#10
  • Aug 16, 2004
  • #10
The holley baby blower (roots style) is very nice. I like the setup better and it doesnt require a lot of routing and plumbing. Drop it on, reconfigure the belts and VAVOOM!! Pricewise it's 6's gonna cost you about 3-5 K no matter which way you go. On carbs, most people go way too big on carb's I thought I would drop a 750 CFM on and go faster... lost 2 10ths in the 1/4...DOH!! too much gas! Anyway just my 2 pennies.
J
jim6577
70
Sioux Falls, South Dakota
Aug 18, 2004
#11
  • Aug 18, 2004
  • #11
this is a simple rume of thumb on carb size. Displacement multiplied by 1.5 to 2. Stay closer to the 1.5 to maintian fuel eficiency or get closer to 2 for maximum performance. This is for normally asperiated engines.
As for supercharging I have looked into several of the kits avaible for my EFI 5.0 and I don't think I have the belt clearence for any of them. Reacentely I saw a pair of headders that are reversed to come forward and mount a turbo from the 2.3's. I think I can build a twin turbo kit using salvage yard parts for under $1000.00. The cool part is that I won't have to worry about headder clearence problems because of my AOD.
98CobraClone
592
Ripley, Ohio
Aug 18, 2004
#12
  • Aug 18, 2004
  • #12
It's my understanding that procharger is testing a carbed setup. Once my V6 poops out, I might get the mounting brackets for a 302 and try it on the cobra. I already know that they produce and sell the carburetor hoods, but getting the piping to run through the SC, and intercooler to the carb would be a pain. At least with a big open grill area of the II, the intercooler would get plenty of air.
I'm just partial to intercoolers now. I'm pretty sure they can be mounted horizontal (parallel with ground) and get an air scoop for it to force ground air into it. I'm still playing with that idea.
kcobra302
864
latham ny
Aug 18, 2004
#13
  • Aug 18, 2004
  • #13
summit page 44 of the new catalog: weiand 174 procharger $2499.99
M
Looking for a passenger side AC Compressor mount
  • mustangTodd
  • Feb 10, 2026
Classic Mustang Specific Tech Aug 22, 2026
s_mi11er
M
Please help me identify this.
  • MattyB77
  • Jul 2, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 4, 2026
gkomo
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
G
Need tuning help with 4100 Carburetor
  • Gary’s 67
  • Aug 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 22, 2026
manicmechanic007
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
