superchips for my car
Superchip Module Superchip performance chips is custom burned to your code on your Mustangs computer so the best chip possible is provided. This is done here on location so we can have it ready in minutes. If you already have a Superchip and you need to recalibrate it, give us a call.
We adjust the ignition timing to take advantage of 91 to 93 octane fuel.
We adjust the air fuel ratio
We firm up the shifts on automatics
We shorten the time it takes the automatic transmission to up shift
On some applications, we will raise the rev limiter and speed limiter
We do not require the use of a 160 degree thermostat which can cause excessive fuel consumption
There's no tricky installation, installation can be performed by anyone with general mechanical ability. If you can change your own oil and filter and change your own spark plugs, you should be able to perform this installation.
Gain up to 10% more horsepower for gas powered vehicles
4.6 up to 18hp & 5.0 14hp
Gain up to 15% more torque for gas powered vehicles
4.6 up to 26tq & 5.0 31tq
Better shifting transmission
Raised speed limiter on most Mustangs.
For applications other then the Rev & Speed calibration please include your FAX number at check out so we can have you fill out a detailed form of your modifications.
Stock# 1100
