Superior EV83 Axles - Opinions?
the boost creep
22
Doing a 31-spline rear end upgrade and came across the EV83s. Anyone here run these and have inputs? There's not much info I can find one them other than they come with outer axle bearing and seals. I'm wanting to know if they are directly compatible with c-clips and ABS sprockets. A few more general questions regarding a rear-end build I have are:
- what size/brand studs should I put in these axles?
- Besides 31-spline differential, ring/pinion, axles and outer axle bearings and seals, what other small things will/should I buy? I've already bought the 03-04 Cobra diff, ARP carrier bolts and TA punkin girdle.
Thanks!
