  • 1994 - 1995 Specific Tech
Surge At Part Throttle
  • Thread starter Thread starter Doug Zinn
  • Start date Start date May 25, 2015
D
Doug Zinn
  • May 25, 2015
I've done another build in a 95 gt. My question is why do tuners not take the time to tweek the part throttle/cruising rpm (1600-2400) in everything I've ever built. My build I'd a 347 stroker, 579/579 comp cam 236/248 @.050, 114ls. Trickflow heads, trickflow upper/lower intake, bbk 75mm tb, mac longtubes, NO egr, 75mm maf, and 36lb fuel injectors. I'm not really that savvy at self tuning to buy a moates, or tweecer system. I'm really thinking about selling off my efi stuff, and going bigish carb set up. I have the money, and is not a DD. What should I DO?
SIKNSLIK
10
panama city,florida
May 25, 2015
  • May 25, 2015
Have you discussed that with the shop tuning it? What did they suggest.
D
Doug Zinn
  • May 26, 2015
Yea!!! I get the same damn answer from every shop go to for the last 4 of the 5 cars I've put together. I have a big cam and have to deal with it. Every one is less then 600 lift.
jozsefsz
1,243
332
124
Cleveland OH Area
May 26, 2015
  • May 26, 2015
What's your complaint about how they've tuned it? To some degree there's only so much they can do to overcome the limitations of your hardware. For example if your header runners are too big you're going to lose some torque. If you're experiencing surging it's possible it's tuned a little lean at low-load cruise RPM's. They should be easily able to adjust that for you. It's actually an area on the dyno that's a little difficult to simulate, sometimes you're better off using a tuner that studies your datalogs than just a dyno session (where they understandably often focus on peak power and idle and often don't spend a lot of time on the in-between).
Personally I'd never go backwards to a carb if I could avoid it. Tons of expense for a poorer experience, in my experience. If you can tune a carb and ignition the old-fashioned way, you can easily do it yourself with Moates / Tweecer. Lots of guys here to help you if you get in over your head. There's also a few guys who remotely tune professionally who could probably get you fixed up.
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Oct 16, 2024
89ripper
98 GT PI Swapped Engine Fires, Dies Immediately NOT PATS
  • MMccPerformance
  • Dec 2, 2023
  • SN95 4.6L Mustang Tech
2K
SN95 4.6L Mustang Tech Dec 20, 2023
Yel2002GTAuto
Y
SOLD 1993 Mustang LX Notchback- 347 Stroker
  • Bzammitt
  • Jun 19, 2021
6K
Fox Body Mustangs For Sale (1979-93) Jul 10, 2021
Bzammitt
J
Learning so much but still have some questions with megasquirt
  • Jweirnik
  • Aug 29, 2020
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 31, 2020
a91what
