surging idle, gas pedal lag, and stall
1994Vib.RedGT
585
Denver, CO
I was at the strip tonight and before I went for my third run my idle started suring from idle to 1500 to dead, and it did it a few times, having to restart my car 4 times before my run. And when I would hit the gas, there was a horrible lag before it would rev up, and the same thing happened when i launched, it lagged like hell and bogged down. what the hell is all this????
Heat maybe. One of the times I went out to the track last summer, I let my brother make a pass (BIG NO-NO!!) and it was running so hot after that one, that the idle would surge real bad, and it would have trouble revving. After a little cool-down period, it was back to normal.
I'd just start with the easy stuff. Pull codes and check electrical connectors to rule out a sensor problem. And then verify spark (wires, correct timing) and fuel. What & when was the last change you made to anything under the hood?
It's probably something simple. Diagnosing over the 'net, however, is hard. :)
Dave
