Surging problem
  • Thread starter Thread starter action
  • Start date Start date Jun 17, 2007
A
action
  • Jun 17, 2007
I own a 1990 LX convertible and dropped a new GT 40 motor in it with GT 40 intake manifold and put 30 lb injectors and calibrated mass air sensor and the motor is still surging. I was told it was because I had stock injectors but same problem with the 30 lb injectors. Ford Tech line said to measure the vacuum pressure at 900 rpms but my car does not idle steady surging up and down below about 1200 rpms. I have the fuel pressure at 40-42 lbs and when I did manage to take a pressure reading, it seemed sufficient. Ford said there is idle recalibration download I can et them to send me but didn't get it from them yet. Maryland performance said it is a common problem and a plug in the intake mainfold you can install that can help. Seems like a band aid for a problem. As I said it seems not to surge if I hold the gas pedal to about 1200 rpms.Any help here?
gambit90lx
  • Jun 18, 2007
me too
i have a gt40 crate engine also with 30# injectors and a c&l mass air meter and i too am having surging issues sometimes not all the time....the thing sometimes almost cuts off and then surges up to about 1300 and then back to almost cutting off...then sometimes it runs perfect.....what kind of maf are you using i am using a c&l and i have heard alot of people saying almost the same thing
ShortThrow50
923
Pa
Jun 18, 2007
  • Jun 18, 2007
I have the same problem with my trick flow h/c/i and am running 24 pound injectors with calibrated C &L maf. I heard c &l ar junk. Mine only does it for about a minute after start up. Soon as I get the cash im gonna buy a diff maf
vristang
4,933
101
124
Seattle
Jun 18, 2007
  • Jun 18, 2007
I am requesting this thread to be moved to the general tech board, as you guys won't get much help here...
http://forums.stangnet.com/showthread.php?t=698148
JR has done a great job with this thread...
jason
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,120
224
Massachusetts
Jun 19, 2007
  • Jun 19, 2007
Moving to tech, will get more views there. Not many come to tuning for some odd reason
9
90bluegt
592
  • Jul 21, 2007
My first question would be 30# injectors? That's a little much I would think, how much horse does the crate GT40 engine put out stock? What throttle body are you using? I'm running a C&L and don't have a issue. I also have a tweecer with a custom tune I created. I had a warm starting surge issue, but I checked everything then realized that it's just plain to rich, so I cleared the start-up table (used as a multipler against the base OL fuel table) and then set the global fuel multipler to 1 (lower than 1 makes it richer, higher than 1 makes it leaner, 1 states just use what's in the OL table). This seemed to fix the issue.
So basically my thoughts are that first your running really rich because the computer thinks you have 19# injectors and the computer doesn't know the proper amount air coming through the TB as well as the correct MAF air flow thus, making it rich, (then the computer uses timing to keep the car running as a secondary if the idle drops to low) and your idle comes back then your rich again and it starts all over. (surging)
This is all assuming you are running a stock computer, sounds like you need to go and get it customed tuned to work properly.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
K
Resolved Need some assistance. Holley Terminator X alongside H/C/I. Very rough/inconsistent idle
  • karhoot
  • Jun 6, 2026
Fox 5.0 Mustang Tech Jun 6, 2026
karhoot
K
C
03 Cobra Low Fuel Pressure
  • CTsnake_03
  • Mar 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
CTsnake_03
C
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
