Surging solved!!!!!
  • Thread starter Thread starter slick88GT
  • Start date Start date Sep 7, 2005
slick88GT
198
Kettering. OH
Sep 7, 2005
  • Sep 7, 2005
I started driving my car again a few months ago and when I'm cruising I get a bit of a surge, the lower the rpm the worse it got. Throttle response suffered too. It had been so long since I drove it last that I couldnt remember when it started doing this. Well after replacing many parts to no avail I finally figured it out. I had previously taken off the egr solenoid and thrown it in the trash because I didn't have the egr valve hooked up anymore. Well I hooked it back up, but just ran a vacuum line straight from the intake to the egr valve. Well, I took my friend's egr solenoid and ran vacuum from intake to the solenoid then from the solenoid to the egr valve like its supposed to be. Car runs like new!!! Throttle response is awesome and it feels like it has more power. If anyone has surge problems, check how your vacuum lines are routed.
slow93
406
  • Sep 7, 2005
i didnt know the egr would cause that but i guess any vacuum leak could
9350coupe
109
chicago
Sep 8, 2005
  • Sep 8, 2005
cool .......at least you fixed problem
you can always get that egr delete kit
D
D347643
Banned
Jan 28, 2003
1,095
portland, OR
Nov 17, 2005
  • Nov 17, 2005
you're not suppose to have straight manifold vac to the egr, its regulated.
HISSIN50
34
129
Nov 17, 2005
  • Nov 17, 2005
Above is correct. The car should have idled and performed like poo with the EGR always open.
Glad you got it.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Nov 17, 2005
  • Nov 17, 2005
Hmmm ... this may be of use for me in my struggle against the impossible Satanic possession my car is suffering. Having similar symptoms, although I'm not running an EGR delete setup. One of the few things left I haven't already replaced. Many thanks...
P
PRO50SC
1,012
Olney, Maryland
Nov 17, 2005
  • Nov 17, 2005
Yeah, I'll jump on that band wagon too.
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
5K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
