  • SN95 4.6L Mustang Tech
Suspension kits
  • Thread starter Thread starter AnnaBanana
  • Start date Start date Sep 14, 2006
AnnaBanana
Denver Colorado
Sep 14, 2006
  • Sep 14, 2006
Need a little help. I am wanting to lower my car about 1"-1 1/2" and I am not sure what suspension kit I should go with. I also would like to improve the preformance of turning corners. Any suggestions?
StangPro
441
Roseville, MI
Sep 14, 2006
  • Sep 14, 2006
that really depends on your use of the car and budget.
EvM, MM, and Steeda have the best packages for handling overall.
nwapache
313
Seattle,WA
Sep 14, 2006
  • Sep 14, 2006
whats your budget....is a really big question.
are you planning on doing any 1/4 mile runs at the track?
Strictly for looking good on the street?
StickShift84
82
Rhode Island
Sep 14, 2006
  • Sep 14, 2006
MM starter box, it made a big difference
www.maximummotorsports.com
T
Torinalth
952
Clayton NC
Sep 14, 2006
  • Sep 14, 2006
well.... whats more important, handeling, or ride height? they dont always go together, no more then an inch for propper geometry (or until you get a full suspension). HR race and bilsteins with CC plates and poly isolators is my suggestion.
Torinalth
san~man
O-G
A little grass shack on a big lava rock
Sep 15, 2006
  • Sep 15, 2006
If you're into turns more than straight lines like me, the proper order is:
LCA's
PHB
Springs, struts/shocks (or CO's) and CC plates if needed
T/A
Read up, do your homework, and buy the correct stuff the first time.
IMO, there are only 2 companies worth a damn....Griggs and MM. Griggs for more of a track duty car (bring your wallet) and MM for more affordable stuff (but still excellent quality, design and performance).
I chose MM personally, and don't have any regrets. I'm running:
MM standard LCA's
H&R supersports
MM CC plates
MM PHB
Bilsteins
Totally different car in the turns.
R
rconaway
1,415
Phoenix, Az.
Sep 15, 2006
  • Sep 15, 2006
Here is the rules I would go by. If you want an all around car (little bit of drag racing or track days) that is used primarily on the street, Steeda and Kenne Bell are good choices. If you are going more towards 100% road racing, then MM would be my next choice. If you want the ultimate street/road race suspension, then an SLA suspension is the only way to go.
I use Steeda control arms/anti-sway bar in the back with a D&D suspension/Maximum combined front end. The D&D was an early mistake but it's being replaced. However, a coil-over with a K-member is probably the most cost effective best handling suspension change you can make. I would also buy Koni double adjustables with it but if not, the Tokico Illumina's aren't a bad choice. Just plan on replacing them every 30,000 miles. I'm on my third set right now.
If you go with a coil-over, stay away from D&D. The system is universal and doesn't exactly fit the shocks. MM and Kenne Bell has a much better system.
san~man
O-G
Sep 15, 2006
  • Sep 15, 2006
I will respectfully disagree with you here.
The most cost effective handling solution is a PHB, not a front CO setup. The biggest suspension problem with a Mustang is the rear live axle setup, not the front. Adding a set of good LCA's and a PHB will make more of a difference than a front CO setup will.
Try calling MM and see what they recommend and the steps they suggest you buy the items if you can't plunk down the coin all at once. They'll tell you the same thing.
Also, I think you meant Kenne Brown too (Kenne Bell makes SC's). Last I heard, he had health problems and none of his children cared to step up and run the business. I don't know if that changed or not, I could be wrong. Besides, the only thing worth a damn from them were the SFC's.
R
rconaway
1,415
Phoenix, Az.
Sep 15, 2006
  • Sep 15, 2006
Oops, my bad. That's what I get for talking on the phone and typing at the same time. I also didn't know he had health problems. I hope that he gets better.
I agree that control of the back is important. The point I was trying to make with the SLA setup was that IMO an SLA is the only way to get a suspension that can handle street and road track simultaneously. I wasn't implying the back end didn't need to be done at the same time.
tomustang
Psychotic Member
3,434
McLean Hospital
Sep 15, 2006
#10
  • Sep 15, 2006
  • #10
..perfectly under lowering conditions and the addition of a thick swaybar in the front combined with super stiff springs, which isn't needed
I like how newb threads get so technical
san~man
O-G
Sep 15, 2006
#11
  • Sep 15, 2006
  • #11
Ya, an SLA setup is nice. To bad only Griggs makes it and it costs you your spare kidney to get it.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Suspension End link replacement size
  • Teen'93stang5.0
  • May 12, 2026
Fox 5.0 Mustang Tech May 20, 2026
Teen'93stang5.0
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 19, 2026
Engine 2003 Mach 1 Automatic Upgrades assistance
  • SJK1417M1AT
  • Sep 25, 2025
SN95 4.6L Mustang Tech Dec 21, 2025
01SVTvertt
