  • 2005 - 2009 Specific Tech
Suspension Questions
  • Thread starter Thread starter BLKNED
  • Start date Start date Aug 27, 2008
BLKNED
67
Aug 27, 2008
  • Aug 27, 2008
I am looking to do some suspension upgrades in a couple months and being that I have never done anything like this before I was looking for some advice on parts. My stang is my dd so 95% of will be on the road with the ocasional run down the strip. I want it lowered and will eventually get new rims, either GT 500, or FR500's in 18's. I have been looking on a few site's, mostly stangsuspension.com but I really don't know what all I want to get. I'm not real concerned with how smooth the car rides afterwords as most as my dd's have been pretty rough ridding. I want a pretty well balanced suspension that will be fun on the streets as well. So what kind of advide do you guys have? Thanks
Damon
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Aug 27, 2008
  • Aug 27, 2008
Tokico D-Specs + Eibach Pro Kit will give you a good stance that still allows you to go over bumps without scraping, and handle nice. You'll need an adjustable panhard bar to bring the rear end back in alignment.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Aug 27, 2008
  • Aug 27, 2008
i recommend anything you find on ~ HotPart.com ~
i have most of their stuff and it is all great quality. i have had zero issues with this stuff, even with track time.
SpartaPerformance
2,517
61
89
Long Island NY
Aug 29, 2008
  • Aug 29, 2008
I have the FRPP handling pack and I love it, the stance is perfect and the vehicle is stable at high speeds....the ride is 90% factory.
V8JamesGT
218
Aug 29, 2008
  • Aug 29, 2008
Eibach Pro Kit, Tokico D-Specs, BMR adjustable Pan Hard Arm bar, BMR Front and Rear Sway Bars, BMR Tower Strut Bar
That would be my suspension if I had the money
J
jack1.1
78
St. Louis, Missouri
Sep 4, 2008
  • Sep 4, 2008
Hello:
These type of questions are alway followed by answers where people, with good intentions, just mention every part in the world, with no real world experience with it.
With the suspension make sure you have access to tools, the support and the plan for what you are doing. Also have lots of cash.
Suspension parts are a source of great dollar drain and sometimes little if no gain from stock if your using it as a daily driver.
Don't just go buy a bunch of parts, half the time that won't get you anything but a waste of money.
With that said, I'm no suspension expert, but for the best bang for the buck, the 1 thing you can do to make an impact in your look, your handling is to get some different springs. I recommend a 1" drop for street driving. Anything lower your going to bottom out or scrape everything.
Now don't forget to ask yourself these questions:
1. buy new ones for about $250
2. figure if your going to install them yourself. If so you need a spring compressor.
3. figure if you want to replace your upper strut plates since you have to take them out with the front springs anyway. If you have over 30,000 miles on it you might want to replace them. They wear out and squeak after a long time. And if you get some maximum motorsports or steeda units (aka camber plates) plan on over $300, but you won't have to pay for camber bolts.
4. Swap in the new springs
5. Go get an alignment, another $100.
6. You'll need camber bolts for the alignment, so add another $50+ to the total unless you opted for upper strut mounts (aka camber plates) see #2 above.
Now you can do a bunch of other stuff, but this is something you'll see results with. Also no need to buy a rear panhard bar, your car already has one. And you only need an adjustable one if your rear is out of alignment. Wait until your done with the install and then see if your alignment of your axle is out (mine wasn't) then buy the part. Why buy something you don't need?
As for tokico shocks, sure they come highly rated (I have no experience with them), but they are also $600 for a set.
As for lower control arms they help control wheel hop some, but not a ton.
Read up here on this site, you'll learn a lot, but just buy the parts you need. otherwise you'll spend a fortune with little if no results.
I have a full Roush S2 suspension (the whole kit) and GT 500 lower control arms.
Jack
Cleaning up Aluminum
  • limp
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2026
KRUISR
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 19, 2026
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
G
Fox 1989 LX suspension suggestion's
  • Gary97
  • May 16, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 18, 2025
limp
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
