  • SN95 4.6L Mustang Tech
Suspension still knocking!
  • Thread starter Thread starter StangYellow
  • Start date Start date Jun 17, 2009
StangYellow
1,052
Jun 17, 2009
  • Jun 17, 2009
Ever since i lowered my car, ive had the worst luck with "knocking" in the front end. I started with Eibach springs, STOCK struts and UPR C/C plates. Since then, i replaced the stock struts with Tokico struts.... still knocked. Replaced the whole front end again with poly coil isolators, poly strut mount bushings. Put it all back together..... still knocks. I simply cannot figure it out. Can it be the C/C plates? This will now be my 4th time doing the front end.
No knocks or for sale!
squeak93
2,318
394
164
Joplin, Missouri
Jun 17, 2009
  • Jun 17, 2009
Are your struts tightened down all the way? Test it by going up by the strut tower and "bouncing" the car up and down. When I first lowered my 04 i used to have it did that too, found out the cc plates shaft was a litte too short for the struts so I used a supplied spacer to fix it and tighten down.
StangYellow
1,052
Jun 17, 2009
  • Jun 17, 2009
I will have to try it tonight. Thanks
mransr
1,188
36
98
Riverside, SoCal
Jun 17, 2009
  • Jun 17, 2009
yes, it could be the CC plates...I had some Steeda ones (I think) and the right side clunked and knocked pretty bad
1low03gt
20+ Year Stangneter
May 24, 2004
708
11
38
Cold Hell,Ontario,Canada!!
Jun 17, 2009
  • Jun 17, 2009
It's mostlikely your C&C plates.99% of them will make a clunk/knock sound.Maximum Motorsports are supossidly the only ones that don't do it,but mine do have this issue slightly,so who knows.Nothing you can do to rid of it but turn up the stereo,and ignore it LOL!
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 17, 2009
  • Jun 17, 2009
UPR plates are JUNK!! thats what is causing your noise.
get MM plates and do it right this time!
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Jun 17, 2009
  • Jun 17, 2009
i have MM 4 bolt cc plates, and i have never heard a single noise from them..........
squeak93
2,318
394
164
Joplin, Missouri
Jun 18, 2009
  • Jun 18, 2009
I disagree with that statement. Once I got them set up correctly, I've never had a set make noise. I've had Ford racing cc plates and BBk, both installed and worked as advertised.
StangYellow
1,052
Jun 18, 2009
  • Jun 18, 2009
Thats what ive been thinking. At the time i just got them because they were the cheapest. Note to self: dont buy products from a company that makes Billet cupholder inserts.
Ill have to get some MM plates. Ive had enough of the clunking.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 18, 2009
#10
  • Jun 18, 2009
  • #10
i've learned my lesson buying cheap UPR stuff too.
i tore the bushing out of my LCA after 1700 miles. UPR sent new bushings, but i ordered some MM extreme duty arms instead
the UPR stuff is fine for a sub 400hp car but it didnt hold up for **** with sticky tires and 600 hp!
squeak93
2,318
394
164
Joplin, Missouri
Jun 18, 2009
#11
  • Jun 18, 2009
  • #11
Great, when you take the upr ones off, I'll snd you money to ship them to me.
R.J.
813
Warwick, Rhode Island
Jun 18, 2009
#12
  • Jun 18, 2009
  • #12
+1 CC plates. I had the Steeda ones and the bearing that the strut goes through would move up and down in the plate against the snap rings causing a loud clunk. Come to find out it was machined wrong I sent it back for a new one. You can check this by putting the car on jack stands then jacking up one side of the suspension. As the strut comes up look for the CC plate bearing shifting in the plate. I have since switch to Hotchkis because they use a rubber insulators at the CC plate bearing to help with noise and harshness.
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
