  • SN95 4.6L Mustang Tech
Suspension time! Got questions!!!
  • Thread starter Thread starter SilverBullet00
  • Start date Start date Jul 17, 2004
SilverBullet00
1,150
Wichita, KS
Jul 17, 2004
  • Jul 17, 2004
For the past month I have been ripping out my hair trying to decide what my next mod should be. little did I know that my fate was already set, my struts/shocks are shot. So I have been looking at the bullitt suspension package and almost ordered it, but now I think I need something more. I am thinking tokico adjustables, FRPP subframes, and FRPP springs. Here is the problem: what springs do I get?! I do not understand the rates at all. I would like the "f" or "g" springs because they offer the 1.0-1.2 drop (I dont want to mess with C/C plates) but what can I expect from them? This is my everyday driver, but I would like a FIRM suspension. Also are the tokico adjustables REALLY worth the money? or will the HP's be enough for my everyday driving and occaisonal racing?
I guess I just need a lot of advise!! HELP!
KaPPaBaLL
1,326
BAYAREA
Jul 17, 2004
  • Jul 17, 2004
Bullitt setup for you if you're not a frequent drag racer. You don't need c/c plates with the bullitt setup
wms004
2,864
Los Angeles
Jul 17, 2004
  • Jul 17, 2004
If you like the drop from the bullitt.. get the springs from www.fordpartsnetwork.com, then get bilstein dampers. That would be plenty stiff. The bullitt springs are 600 compression front and 250 rear which is stiffer than a lot of the FR springs. Then skip the FRPP subframes and get Griggs racing ones.. Then Maximum Motorsports LCA's. The LCA's are the WEAAAAAKest link in our suspension. I put on the MM LCA's and removed the quad-shocks.. Night and day.
-wade
Red mustang Gt 46
601
Good ol' Maryland
Jul 17, 2004
  • Jul 17, 2004
The Bullitt suspension package is a nice set up for a daily driver...FRPP "B" springs compare to Steeda Sport springs, "C" springs are a little bit stiffer. As stated above, control arms make a WORLD of difference in how your car will handle, steering and straight ahead performance.
SilverBullet00
1,150
Wichita, KS
Jul 17, 2004
  • Jul 17, 2004
sounds cool, but i still dont understand the spring rates and how they work? I would like it to be just a little lower than the bullitt suspension, but i would also like to add LT headers later on with no ground clearence problems....also where is the cheapest place to pick up some blisteins?
Red mustang Gt 46
601
Good ol' Maryland
Jul 17, 2004
  • Jul 17, 2004
Are you looking for looks or handling? Dropping lower than 1" will hurt performance...
wms004
2,864
Los Angeles
Jul 17, 2004
  • Jul 17, 2004
I scrape over some speed bumps with my magnaflow catted X.. with longtubes and more than a 1" drop you will scrape a lot.
Try www.shox.com for the bilsteins.
T
Too Slow
209
Houston, TX
Jul 17, 2004
  • Jul 17, 2004
i say if you wanna get the bullit suspension get different shocks than the tokikos that come with it. they handle good while they are fine but like after 2 years say hello to new shocks and struts cause they will blow eventually.
V
V8MstngPwr
70
Rio Rancho, NM
Jul 17, 2004
  • Jul 17, 2004
If I had a choice of suspension parts I would go Steeda G-Trac all day long... maybe that's just me though.
KaPPaBaLL
1,326
BAYAREA
Jul 17, 2004
#10
  • Jul 17, 2004
  • #10
ebay. type in mustang bilstein. LT's later will scrape if you go any lower. i still say bullitt kit.
wms004
2,864
Los Angeles
Jul 18, 2004
#11
  • Jul 18, 2004
  • #11
Where did you get that info from.. just curious if there is any backing so i know when to look for issues.
C
Cali03Boss
280
Del Mar, CA
Jul 18, 2004
#12
  • Jul 18, 2004
  • #12
MM for everything. Period. Subframes, LCAs, Sway bars, and panhard + torque arm would give u fatty grip for those launches.
wms004
2,864
Los Angeles
Jul 18, 2004
#13
  • Jul 18, 2004
  • #13
and don't forget griggs
SilverBullet00
1,150
Wichita, KS
Jul 18, 2004
#14
  • Jul 18, 2004
  • #14
Another question: what about the tokico kits? the HP series that come with the springs? anybody know much about them?!
White Stang
467
Ft Lauderdale
Jul 18, 2004
#15
  • Jul 18, 2004
  • #15
I Installed the Ford c-springs and am very happy with there performance over stock they still give me drivability to avoid bottoming out on speed bumps and clearing parking stops. Here is a pic so you can see where c-springs will drop your cars stance to.
J
JHRide00
350
#16
  • Jul 18, 2004
  • #16
so what is the difference between getting shocks and struts and getting coilovers? What exactly are coilovers???? (are they just springs?) I got all confused when looking for the right suspension myself.
SilverBullet00
1,150
Wichita, KS
Jul 19, 2004
#17
  • Jul 19, 2004
  • #17
why do some shocks and stuts say they are for lowered cars? can you not use a standard size strut and shock with some lowering springs?
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
