Suspension Upgrade Suggestions
  • Thread starter Thread starter 5.0 Nostalgia
  • Start date Start date Feb 2, 2015
5.0 Nostalgia
904
CT
Feb 2, 2015
  • Feb 2, 2015
I am looking to upgrade the stock suspension in my car over the next month so I can get it ready for spring. The car is basically a street car that may see an occasional trip to the track so I am looking for the best all around performance in terms of handling and hook up. My engine is a N/A 331. I don't have plans on doing a power adder. The suspension is currently all of the original components (car has 102k on it). So far I purchased a set of Koni yellow shocks, struts, and quad shocks for the upgrade. I am looking to do springs, rear control arms/bushings, and front bushings. I am undecided on coil over or stock set up for springs, but realize I probably don't need to go that far. My original thought was UPR upper and lower control arms.
Anybody have suggestions based on the info I have given?
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 2, 2015
  • Feb 2, 2015
First thing to do is add MM full length subframe connectors. Then I would do the following
Springs- H&R or Steeda Sport Springs, and poly isolators
Front- new poly sway bar, end link bushings and new poly A arm bushings
Rear- MM rear lower control arms and new stock upper rear control arms, new control arm bolts, new sway bar bushings,
Reactions: aar0s
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 2, 2015
  • Feb 2, 2015
TeamZ rear control arms. If you haven't already done it make sure to check the torque boxes(get them reinforced)and add subframe connectors. Keep the rear springs with a coil cut are the best/cheapest option. If you do decide to go coilovers get the maximum motorsports kit. It's the best one(imo).
5.0 Nostalgia
904
CT
Feb 2, 2015
  • Feb 2, 2015
I forgot to mention that I already have Global West full length subframe connectors and upper and lower torque box plates.
Reactions: A5literMan
Sharad
ALWAYS choose the V over the P!!! Wait... what?
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Feb 5, 2015
  • Feb 5, 2015
I would recommend UPR Pro Street upper & lower control arms for your setup. They have polyurethane bushings on one side and solid bushings on the other end, so you get the power handling ability & free articulation (no bind) of a spherical bearing with the quieter operation of a polyurethane bushing. It's a best of both worlds scenario. I would remove the quad shocks, as they won't be needed with the UPR control arms.
I'm not a fan of stock location rear coilovers on a fox body because they sacrifice some tire clearance. We have a very popular adjustable rear spring kit which mounts in the stock location, so you maintain full tire clearance.
UPR Products are Made in American, and they carry a Lifetime Guarantee. Also, we offer Stangnet members a 10% discount using code forum15. If you call us at 561.588.6630 we'd be happy to discuss these options in more detail.
Thank you for considering UPR Products!
90lxwhite
I'm kind of a She-Man
5 Year Member
Aug 25, 2011
3,310
374
134
Between the Red and Rio
Feb 5, 2015
  • Feb 5, 2015
Quick thread-jack. Why does everyone want to remove quad shocks after upgrading rear control arms? Saving 4lbs? I understand doing away w the quads to make room for wider tires but what negeative affect is there w running quad shocks w aftermarket control arms?
Reactions: aar0s
aar0s
1,015
55
69
Feb 5, 2015
  • Feb 5, 2015
What mikestang said.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Feb 5, 2015
  • Feb 5, 2015
Yo mike, do the poly bushings in the frontend help a great deal? Are there any negative trade off's using urethane vs rubber like there are in some cases w the rear suspension?
rbohm
6,698
550
204
tucson,az
Feb 5, 2015
  • Feb 5, 2015
my advice;
springs-go for a slightly stiffer overall spring, but get a progressive rate spring. that way you maintain a good ride while improving handling.
sway bars-use the stock bars, just upgrade the bushings and end links to poly items. i recommend energy suspension greaseable units.
control arms- lower rear i recommend these;
http://www.hotpart.com/1979-1998-1999-2004-mustang-rear-lower-control-arms-for-street-race/
for the upper arms go with stock units.
for the front arms, again stock replacement units preferably with poly bushings, again greaseable ones are best.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
Feb 6, 2015
#10
  • Feb 6, 2015
  • #10
^^^ They look and read very similar to the MM rear lca I just had installed....
Sharad
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Feb 6, 2015
#11
  • Feb 6, 2015
  • #11
Because the quad shocks were just a bandaid for the sloppy bushings Ford used in the factory control arms. Upgrade the control arms, bandaid no longer needed.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Feb 6, 2015
#12
  • Feb 6, 2015
  • #12
I get the bandaid part but wouldn't it have even less wheel hop when using both?
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 7, 2015
#13
  • Feb 7, 2015
  • #13
Short answer is no. By a quality control arm and bushings and there is no need for the quads. I've never experienced wheel hop with a good setup.
Reactions: Sharad
Sharad
Jan 5, 2011
1,562
480
94
Fort Myers, Florida
Feb 7, 2015
#14
  • Feb 7, 2015
  • #14
^^what he said
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Feb 7, 2015
#15
  • Feb 7, 2015
  • #15
Sharad said:
^^what he said
they'll have no affect negative or positive with a good control arm setup so the advantage in removing them is a reduction in 4 lbs.
A5literMan
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 7, 2015
#16
  • Feb 7, 2015
  • #16
Removing them reduces weight and increases wheel/tire clearance without effecting suspension performance.
90lxwhite
5 Year Member
Aug 25, 2011
3,310
374
134
Feb 7, 2015
#17
  • Feb 7, 2015
  • #17
Thanks got ya.
2000xp8
Aug 8, 2003
8,060
1,645
194
NJ
Feb 8, 2015
#18
  • Feb 8, 2015
  • #18
IMO, as someone that has had a boat load of suspension parts, just browse the maximum motorsports catalog and build it from there. The koni's are a good start. Coil overs in the front will be good, rear's i'd stick with regular springs.
Not a fan of cutting springs, I've done it more times than I can remember and have never been happy with it. It's a crapshoot on how the car will sit and ride. Get the weight jacker MM rear controls to help control the height of whatever springs you get.
As for the wheel hop, I feel like that's an individual car thing, I've had wheel hop and not had it with just a change of tires, so....
If you don't need the clearance, imo, leave them. If you do, well then they are going.
Suspension is the place to stick with higher end parts, in the long run it will save you money.
Reactions: mikestang63
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Thursday at 9:34 PM
Qtrhrse23
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
