  • SN95 4.6L Mustang Tech
Suspension
  • Thread starter Thread starter 1QWK96GT
  • Start date Start date Sep 9, 2008
1QWK96GT
44
  • Sep 9, 2008
Hey everybody. I have a 96 GT and this winter I plan on removing the engine and building it for boost. Well I decided to install a steeda qa1 k member to make the removal easier since the long tube install was difficult with the stock k member. So when I went to install the k member I had to modify a arms bolts and grind down the a arms. The car was already lowered. Once I let it down on the ground the k member must of lowered the car more because now the tires are sitting up in the fender well almost sitting on the fenders. The alignment is WAY off which I kind of expected but not as bad. I called QA1 and they said it is not for street use and that it will only work with skinnys up front and track use only. My question is what do I need to do to correct all this? Do i need coilovers,x2 balljoints,caster camber plates, tubular control arms, and aftermarket struts? Or should I just get ride of this k member and look elsewhere. I like the added room and weight savings. I am looking at coilovers to bring up the front end since its bottomed out. I was thinking about buying this http://cgi.ebay.com/ebaymotors/79-0...arms=39:1|65:1|240:1318&_trksid=p4506.c0.m245 and buying my own springs to use with it. Has anyone used dynamic racing coilover kit? Is it any good? Can I use any aftermarket coilover spring with it? Thanks in advance
02nightmaregt
To hell with your Mustang, I want to see your HOG!
Jul 1, 2007
513
Southern Indiana
Sep 9, 2008
  • Sep 9, 2008
ebay is kinda sketchy. Just my .02 cent. You wood probably benefit from a full tubular/coilover front end so you could raise up the front end though.
1QWK96GT
44
  • Sep 9, 2008
Thats what I was thinking ebay is sketchy but with me needing all this crap Im trying to save a little dough and I thought maybe someone else has had experience with it.
oxfordgt
288
Clarksville, TN
Sep 9, 2008
  • Sep 9, 2008
I have a QA1 kmember with their Aarms and coilovers and it rides and tracks just fine. It is completly streetable. I would suggest coilover so you can adjust the height but buy real coilovers and not the crap you find on ebay.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Sep 9, 2008
  • Sep 9, 2008
i would only really buy from Maximum Motorsports, Griggs or Agent 47, but thats me and they make products i would use.
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
G
2001 Mustang GT noise after header and control arm (x2) install
  • gilmo5
  • Jan 8, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jan 12, 2025
weendoggy
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
  • dan50
  • Jul 18, 2026
dan50
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
