SVT Fuel Pump
  • Thread starter Thread starter evil281
  • Start date Start date Jul 31, 2008
evil281
276
Arizona
Jul 31, 2008
  • Jul 31, 2008
at what point do you really want to get a better fuel pump or does it just help anyway? i need to be schooled on the fuel system, i have about 250rwhp and 288rwtq plans of power adder in a year or so
CobraRed_96_GT
1,421
UCSD/La Jolla
Jul 31, 2008
  • Jul 31, 2008
when you get the FI you'll need it, not before then. There's an equation you can use to figure out how much your your injectors can support as well.
SilverBullet00
1,150
Wichita, KS
Aug 1, 2008
  • Aug 1, 2008
You dont even have to think about the fuel system untill 300+ RWHP.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Aug 1, 2008
  • Aug 1, 2008
you need to buy my fuel system.......you'll be safe to 800 rwhp
blksq10psi
114
PHILLY
Aug 1, 2008
  • Aug 1, 2008
if youre gonna go with a power adder you cant go wrong with an 03 cobra pump pretty much plug and play... but with the cobra pumps in a gt tank u need to keep a 1/4 tank or the pumps will suck them selves dry and you will need to remove the bracket that holds the stock gt pump in the tank. i had svt focus pump waste of money the pump will suck the bucket dry
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Aug 3, 2008
  • Aug 3, 2008
not true at all. you should have modded the bucket. (two 1/2" holes in the bottom) and you would have been fine to 420 rwhp. you need 1/4 tank or more to be in boost
D
darkside03gt
851
Sacramento CA
Aug 3, 2008
  • Aug 3, 2008
drilling holes in the bottom of the bucket is a bad idea because the bucket is designed to fill and hold fuel. by drilling holes in it you take a bigger chance of fuel running away from the pump when the tank gets low. I did alot of re-search into this and its not a good idea. the focus pump doesnt really flow that much more then the stock gt pump and its not enough to drain the bucket before it can be filled. the svt pump isnt 255lph like some people believe.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Aug 3, 2008
  • Aug 3, 2008
it was recomended by MPH. you MUST run 1/4 tank or more all the time
blksq10psi
114
PHILLY
Aug 3, 2008
  • Aug 3, 2008
i was being told that 03 cobra pump in a stock gt tank you need to keep 1/4 tank because there are no baffles in the tank the fuel would slosh driving around corners i didnt know about being under boost also i never really run the tank past 1/4 anyway
blksq10psi
114
PHILLY
Aug 3, 2008
#10
  • Aug 3, 2008
  • #10
what kind of fuel pump are are you running?
thread no longer needed
  • skidad
  • Oct 17, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
skidad
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
FUEL PUMP ALWAYS ON
  • Scwhitten
  • Jun 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
Scwhitten
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
