  • 1994 - 1995 Specific Tech
swap questions
  • Thread starter Thread starter wheely man
  • Start date Start date Nov 26, 2007
W
wheely man
17
  • Nov 26, 2007
I have a 95 mustang v6 and im doing a 95 v8 swap. I already know pretty much what to do bout the motor and stuff but I bought a donar gt and i was wondering if I should swap out anything from the suspension that would be beter than my v6
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Nov 26, 2007
  • Nov 26, 2007
Definitely the rear end. The V6 models use a 7.5 inch rear, while the GT/Cobra used the 8.8 inch. The brakes should be the same between the two.
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Nov 26, 2007
  • Nov 26, 2007
The brakes are 100% identical. The suspension should be as well, though I really don't know if the front springs are. Anyone else know this?
You didn't mention the transmission. The AODE is different between the two cars, the GT's AODE is a bit beefier. Anyone know for sure if the V6 AODE or T5 will bolt on to a GT? I'm pretty sure they won't exchange.
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Nov 27, 2007
  • Nov 27, 2007
Use the V8 springs if you want to have the stock ride height of a GT. The V6 springs will lower the car a little with the V8 motor. Use the 8.8 rear end for sure. I would personally use every single thing you can from the V8 car. I would even use the dash and body harnesses if one car has more options than the other. It makes everything much easier.
W
wheely man
17
  • Nov 28, 2007
Thanks guys. I just wanted to make sure I got every good part out of the car that I can before I sell the stuff!
Also is there any cheap horse power that I can put on that would be easier with the motor out of the car?
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Nov 28, 2007
  • Nov 28, 2007
Agreed on the springs. I have aftermarket springs already, so that's not an issue in my V6-to-Cobra swap. Except for the instrument cluster, the dash is identical for 94-95 Mustangs.
wheely man, I'm doing my swap right now. Feel free to PM me with any questions. One thing you WILL need to do is swap the hard brake line leading from the passenger's front wheel well to the rear axle. The V6 cars have their brake line in the right side, and the GT/Cobra's have it in the center.
W
wheely man
17
  • Nov 28, 2007
thanks but i wanted the car to sit a little lower, but ill get the proper springs for it when im done and when I get the money for it.
BlackVert
5,589
9
98
Bethesda, MD
Nov 28, 2007
  • Nov 28, 2007
you can also check here: www.sorscode.com
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
1994 - 1995 Specific Tech May 21, 2026
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
