progress.....perhaps.
I haven't had ANY time due to being on call this week, I've already put 70 hours in, and this weekend isn't even here yet.
however for a friday treat, I went straight home after work and disconnected the brake booster line from the vacuum tree and stuck that puppy in mouth and sucked like Ginger Lynn.
First observations is that it seemed to be a lot easier to suck in than sn boosters I've tried this with at the junkyards. (no I couldn't find a vacuum pump just yet. My bro has ours, and autozone doesn't have any to loan). I then sucked sucked sucked using my tongue as a sort of wratchet to build up extra pressure, then held for a moment. Moments later I tried sucking even more and could.
Unofficial observations lead me to believe my 186k mile oem booster has gone south.
I went ahead and fired her up with nothing connected to vacuum except pcv, map sensor, and fuel pressure regulator, and let her idle and revved the hell out of her. absolutely no popping and no bogging whatsoever. This is good news. I then stuck my nose up the tailpipe and got no wiff of rich fuel whatsoever, even during cold operation.
Unfortunately the tanks is just about dry and I can barely keep my eyes open, so a test drive will have to wait for tomorrow or Sunday. I will keep you all posted. FYI, this is the best this car has ever run yet with this intake, so I'm just about postive it's nearly dialed in to at least drive and play with now. I'll update further this weekend after the test drive.
If it is a bad booster, my guess is going to this bigger ported gt40 style intake had less vacuum than the oem intake, thus making a slightly leaking booster a much bigger deal.
__________________
__________________
