Swapping a c6 for a c4, whats needed?
  • Thread starter Thread starter hummer784
  • Start date Start date Jan 2, 2004
H
hummer784
332
Danville, Ca
Jan 2, 2004
  • Jan 2, 2004
I am finally getting rid of my c6 for a nice small c4 and I was curios what was needed for the swap. The car is a 67 coupe with a 289 and an 8". Will I need a new crossmember or drive shaft? I have a cable shifter so that wont be a problem. Thanks!
allcarfan
The Answer Man
2,458
North Atlanta
Jan 2, 2004
  • Jan 2, 2004
I dont think you will need anything. You MIGHT need a different crossmember, but I doubt it. Good luck.
mustang70
2,445
San Diego
Jan 2, 2004
  • Jan 2, 2004
You'll need the C4 crossmember. I think it sits further foward. I'm sure you'll need a longer driveshaft as well. The C6 is a couple inches longer then the C4.
D
D.Hearne
11,730
south louisiana
Jan 2, 2004
  • Jan 2, 2004
You'll also need a different slip yoke for your drive shaft. C-4's are 28 spline, C-6's are 31 spline.
D
D.Hearne
11,730
south louisiana
Jan 2, 2004
  • Jan 2, 2004
The flexplate will also be different on the C-4 if it has a 157 tooth bell housing.
D
Yet another v8 swap
  • dulcimerbob
  • Sep 19, 2026
  • 4 5 6
3K
1974 - 1978 Mustang II Talk & Tech Tuesday at 7:10 PM
LILCBRA
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
