Symptons of a bad steering rack
87lc2
214
Wondering if this is a bad steering rack...There is a squeaking when turning the wheel back and forth(not the pump whining), and the wheel does not turn back to center. If anyone has had these experiences, please chime in if it matter, i replaced the power steering pump about 3 months ago and havent had a problem with it.
It can also be bad ball joints, tie rods or something that's sitting against the steering shaft. Ball joints will squeak when all the grease is gone and they affect caster and camber, which affects return-to-center and Kingpin.
If all else checks out, I like the rack idea.
Good luck.
Being a GM guy, im not too familiar with the rack and pinion setup, where are the inner tie-rod bushings? It looks to me like there is the rack, and then outer tie rods? Ill go ahead and check the ball joints and tie rods first befor ei go ahead and replace the rack
