SYNC stopped recognizing g/f's phone
  • Thread starter Thread starter '13_ImpactBlue_GT
  • Start date Start date Oct 19, 2011
1 of 2 Next Last
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Where the men are men and the sheep are nervous
Oct 19, 2011
  • Oct 19, 2011
Is there a way to reset SYNC or just delete the phone and re-add it?
stanmckinney
1,188
Oct 19, 2011
  • Oct 19, 2011
Yes, but be aware there are some Sync problems with newer cars.
It is a software issue that Ford has tried to fix but not been totally successful with.
Svtpilot
944
59
59
Long Island, NY
Oct 19, 2011
  • Oct 19, 2011
Maybe your car doesn't like you girl.
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Oct 19, 2011
  • Oct 19, 2011
SpartaPerformance
2,517
61
89
Long Island NY
Oct 19, 2011
  • Oct 19, 2011
There are only 25 phones that are compatible with SYNC, I'm betting hers is not one
C
cvialp5901
  • Oct 20, 2011
Sync Reset
There is a Fuse that needs to be pulled, the fuse panel is located in the passenger foot well. Pull sync fuse for 5-10 minutes (look in manual for fuse location). This will fully reset the sync system. I also would take it down to your local dealer and have them install the latest Sync update.
SpartaPerformance
2,517
61
89
Long Island NY
Oct 21, 2011
  • Oct 21, 2011
Latest software wont help if the phone is not one of the 25 compatible ones, the system will spazz out again
MRaburn
Founder
Admin Dude
334
174
Auburn, AL
Oct 22, 2011
  • Oct 22, 2011
Reply Test
stanmckinney
1,188
Oct 22, 2011
  • Oct 22, 2011
My wife has had problems with her phone on a 2011 Fusion. Same make and model of phone works fine on my 2010 Mustang. My wife's car also sometimes does not recognize her ipod though my car will recognize the same iPod. She has had the update (the car, not her personally). There are still some problems. I would think Bluetooth should be pretty universal. It is also odd that an older car works while the newer does not.
Sync is great when it works properly. Ford needs to fix this. It would keep me from getting a newer model.
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Oct 25, 2011
#10
  • Oct 25, 2011
  • #10
Well, it is now working......just no voice activated option.
Az Pete
711
18
49
Panama City, Fl.
Oct 25, 2011
#11
  • Oct 25, 2011
  • #11
My sister had a sync/phone problem in her '12 Explorer Limited. Would not connect. Dealer removed her phone completely from sync, removed the phone battery, reloaded the phone into the truck....no issues now. This was after two weeks of the phone working good after purchasing the Explorer.
SpartaPerformance
2,517
61
89
Long Island NY
Oct 25, 2011
#12
  • Oct 25, 2011
  • #12
Ummm... then it's really not working! If she's not eligible for a phone upgrade and she's unwilling to purchase a proper phone then only thing you can try is disconnecting the battery for about an hour, this hard reboot should wipe the memory entirely clean hopefully clearing any data corruption from outside devices.
Same issue, there are only 25 phones that 100% compatible with SYNC and MyTouch. I reboot 4 -5 each day. Ford finally recontracted Microsoft (Ford got cheap and attempted to do it on their own) to make one final software update hopefully coming out in January. I'm tired of the whole thing.
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Oct 25, 2011
#13
  • Oct 25, 2011
  • #13
Ummm... then it's really not working! If she's not eligible for a phone upgrade and she's unwilling to purchase a proper phone then only thing you can try is disconnecting the battery for about an hour, this hard reboot should wipe the memory entirely clean hopefully clearing any data corruption from outside devices.(
Everything SYNC related worked the day she got the car and she had the same phone then as she does now..........Samsung Reality II same as mine.
SpartaPerformance
2,517
61
89
Long Island NY
Oct 26, 2011
#14
  • Oct 26, 2011
  • #14
AHHHH HAAA
1) The problem is hers is set as the secondary phone I guess. It wont recognize hers when yours is in the car too. Both phones in car at the same time yours as the primary will have to be turned off to read hers.
2) If they are the exact same phone perhaps the system is have a "brain fart"
'13_ImpactBlue_GT
Angry Little Elf
Mar 30, 2005
872
Oct 26, 2011
#15
  • Oct 26, 2011
  • #15
AHHHH HAAA
We never added my phone to her SYNC......
SpartaPerformance
2,517
61
89
Long Island NY
Oct 27, 2011
#16
  • Oct 27, 2011
  • #16
Well then you have a non compatible phone so your only choices are to upgrade the phone or perform a hard boot by disconnecting the battery for an hour
FordCustSrvc
508
37
29
Dearborn, MI
Oct 31, 2011
#17
  • Oct 31, 2011
  • #17
Hey 2011_Ram_RT,
PM me your VIN, along with the phone type and carrier, so I can work with my In-Vehicle Technology team on your issue.
Hi stanmckinney!
I responded to your other post, but I'll copy it here to make sure you see it. Which HTC phone do you have, and what's the carrier? Also, does the Fusion have Navigation? I'll work with IVT on yours as well. Thanks!
~Natasha
D
DoubleTap
61
Oct 31, 2011
#18
  • Oct 31, 2011
  • #18
Me too
phone into the truck....no issues now. This was after two weeks of the phone working good after purchasing the Explorer.[I /QUOTE]
I just got off the phone with the SYNC center. I did a master reset and repaired the phone . I have a 12 for 8 weeks and the phone worked fine until today, the phone is an HTC EVO 4G.
SpartaPerformance
2,517
61
89
Long Island NY
Oct 31, 2011
#19
  • Oct 31, 2011
  • #19
Unfortunately you're going to continue to have issues. If you schedule an appointment with your dealer they can try an upgrade most likely some or all of the fields are empty and they need to click the check boxes and add "NULL" file but again this will only be temporary. If the EVO 4G is a compatible phone hopefully it will last a few more short months.
SYNC gen 1 was designed by Microsoft and is virtualy bullet proof, MyTouch was done in house by Ford and so far it pains me to say it has been an epic fail. Ford has recontracted Microsoft and they expect a final permanent patch to be available sometime in January. I'm crossing my fingers! I feel for you and all my customers but be patient the fix is coming.
D
DoubleTap
61
Oct 31, 2011
#20
  • Oct 31, 2011
  • #20
I can wait
I am a patient person and can wait until January. However if they can't fix the problem and my patience wares thin, Ford is the party that will be unhappy. I can be and have been in the past, a VERY litigious person with access to virtually free legal representation.
1 of 2 Next Last
R
Fox Hydroboost conversion/proportional valve
  • RubyRedNotch
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 20, 2026
RubyRedNotch
R
Can anyone tell me why this one particular fuel hanger lines are like this
  • from6to8
  • Apr 5, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Apr 8, 2025
from6to8
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
T
Losing Refrigerant rapidly on my 98 Mustang GT
  • TekoSn95
  • Jun 21, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
TekoSn95
T
