  • SN95 4.6L Mustang Tech
Synchro going bye bye?
  • Thread starter Thread starter merc123
  • Start date Start date Jun 29, 2004
merc123
420
North GA
Jun 29, 2004
  • Jun 29, 2004
Recently when shifting into 2nd it almost seems like the shifter is getting "stuck" on something. It doesn't do it when I'm shifting hard but if I'm just cruising it feels like it's sticky. It's a mushy feeling, not solid almost as if there is a piece of rubber that I'm pulling against to go into gear. Is it the synchro?
J
jbrown
393
Tallahassee, FL
Jun 30, 2004
  • Jun 30, 2004
You might want to look at your tri-ax. After putting mine in I guess I didnt tighten down the stop bolts all the way, well they rattled loose and I lost 2nd, 4th, and reverse one night. I got stock in the middle of a parking lot blocking cars and had to call my girlfriend and have her bring me my tools so I could fix it(thank god she brought what I asked for). It sounds like that could be the problem since it doesnt happen when you shift hard, check it out before taking it to a shop.
silvernuts
12
jc missouri
Jun 30, 2004
  • Jun 30, 2004
Ford dealer warned me not to hammer down on 2nd said the synchro in 2nd was "made to break"..at least thats what he said..
M
MustangLife
1,285
Chattanooga, TN
Jun 30, 2004
  • Jun 30, 2004
If its a getting stuck kinda feeling its most likely a bent shift fork. If it breaks you won't be able to go into that gear. If its a mushy feeling It might be a blocker ring. If it grinds which you didn't say it was is probaly a synchro.
josh
merc123
420
North GA
Jun 30, 2004
  • Jun 30, 2004
Blocker ring as in something that prevents you from going into a gear (like the 1st gear above 10MPH block)?
It feels like it's getting stuck but it's a mushy stuck. It doesn't grind.
03poontanggt
296
fresno ca
Jun 30, 2004
  • Jun 30, 2004
I am having the exact same problem. It makes it real hard just to cruise around at slow speeds. I don't have any problems with 4th or rev. And I do grind ever other day or so
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
