synthetic oil question
  • Thread starter Thread starter garystocker
  • Start date Start date May 28, 2007
garystocker
305
New Jersey
May 28, 2007
  • May 28, 2007
I was told one you try synthetic oil you must never go back to natural-regular refind oil. Is this true??
If so why would you have to stay with synthetic? What could possibly happen if you did switch back??
2nd Mustang
2,488
Southern California
May 28, 2007
  • May 28, 2007
I really don't know the answer to your question, BUT, I did switch to synthetic on a high mileage motor once and regretted it. Yes, it did seem to run a lot smoother, but it developed little leaks that weren't there before. Switching back to dino oil didn't help the situation.
rbohm
6,698
550
204
tucson,az
May 28, 2007
  • May 28, 2007
that is a load of bravo sierra. you can switch back and forth anytime you like after the engine is broken in. break in should be done with conventional oil otherwise parts dont wear in properly.
rbohm
6,698
550
204
tucson,az
May 28, 2007
  • May 28, 2007
actually it didnt develop leaks, they were there already. what happens in that synthetic oils are much more aggressive at cleaning out engine deposits that the deposits that were plugging the leaks were cleared away. by the way, modern conventional oils are getting very aggressive at cleaning and keeping an engine clean and free of deposits as well.
E
entdoc
89
greenville, SC
May 28, 2007
  • May 28, 2007
not only can you go back ,you can mix the two without problem
fvike
335
Mosjøen, Norway
May 29, 2007
  • May 29, 2007
I'm planning on running Agip Racing 10W-60 and STP Oil Treatment. I read on another board that the STP Oil Treatmnet adds sink to the oil, which helps the cam to survive. Gonna break in the engine with regular oil.
BTW, I got a question; I've just had my engine apart for the first time, nothing major except new rings, gaskets, and bearings. Does the cam need to be broken in again ? It's a hydraulic flat tappet.
J
Jimmys66
419
Paw Paw MI
May 29, 2007
  • May 29, 2007
BTW, I got a question; I've just had my engine apart for the first time, nothing major except new rings, gaskets, and bearings. Does the cam need to be broken in again ? It's a hydraulic flat tappet.[/QUOTE]
No, but you should put the lifters back into the same bores you got them out of. A cam and a lifter wear in together making a certain pattern for lack of a better word.
If you put the lifters back onto a different cam lobe they will have different patterens and will cause the cam and lifter to wear into each other again. This kinda makes for more wear than it really should have.
StangDreamin'
583
2nd Ocotillo bush east of the Colorado River; Sout
May 29, 2007
  • May 29, 2007
As far as mixing synthetic and dino oil; Ford recommends their "Synthetic Blend" everywhere in the owner's manual for my '02 F150; and it appears that it was used exclusively in my truck (owner always took it to the dealership for that stuff) until I bought it!
Since then, it's been fed Mobil 1 "Extended Performance". A little cheaper than Auto Parts House prices when bought by the "1-1/4 gallon jug and 1 quart bottle" (total of six quarts per oil change) from Wally World and changed in my carport.
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 4:43 AM
manicmechanic007
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
O
Sooty/Oily Front Engine & Pulleys
  • ozenator
  • Jun 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 22, 2026
Blackhawkxx
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
