Synthetic Oil?
  • Thread starter Thread starter mattmcdan
  • Start date Start date May 8, 2006
mattmcdan
176
Okeechobee, Florida
May 8, 2006
  • May 8, 2006
Is it ok to switch to synthetic oil? I can't find any info on this at all. I have a 91 5.0 I just freshened up for my 86 vert. Reused rods, pistons, crank, but I did clean them up.
HISSIN50
34
129
May 8, 2006
  • May 8, 2006
The big worry with synthetics is with ring seal with new rings and clean bore surfaces. If you freshened things up that much, I might run dino oil for a little bit (most of the ring seal should occur within minutes of operation).
I would be doing a break-in period of sorts no matter how much or little was done inside the motor. And dino oil is what I would choose for that short OCI.
MHO.
Good luck.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
May 8, 2006
  • May 8, 2006
dino to break it in and synth after that
88stangmangt
2,332
Stafford,VA
May 8, 2006
  • May 8, 2006
um rings seating within minutes???? i dont think so......try for a proper break in of rings 8-10 track passes or a good 500 miles.....I would run 10w30 dino oil for the first 1-2k miles then i would change filter/oil to synthetic at that point if you prefer.
mattmcdan
176
Okeechobee, Florida
May 9, 2006
  • May 9, 2006
good ol' Castrol 10w30 then its Mobil 1 Thanks a bunch.
69Rcode_Mach1
1,473
Salt Lake City, Utah
May 9, 2006
  • May 9, 2006
You would be surprised HISSIN50 is right the initial runs on the car are where a lot of the seating occurs if you run it hard with a good load on it.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
Wheels-Tires Factory white ponys, anyone know a color match paint for them?
  • rednotch
  • Apr 26, 2026
Fox 5.0 Mustang Tech Apr 27, 2026
rednotch
