synthetic oil
  • Thread starter Thread starter 65springtime
  • Start date Start date Dec 19, 2010
65springtime
61
Mayfield, Ky.
Dec 19, 2010
  • Dec 19, 2010
I have around 114,000 miles on my 65 coupe and was wondering if there would be any problem changing over to 10w30 Mobil 1 synthetic oil? Would I need a sprcial oil filter? Thanks
mtaqua
345
  • Dec 19, 2010
hyd or solid cam? (non-roller); seems several people have been loosing cam lobes due to a lack of zinc in newer oils. Maybe look for something with zinc, I think Royal Purple and Brad Penn both have it (both have synthetic).
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Dec 19, 2010
  • Dec 19, 2010
With that many miles on the engine, you will probably wind up with oil leaks.
65springtime
61
Mayfield, Ky.
Dec 19, 2010
  • Dec 19, 2010
Why would you say that? What would cause the oil leaks?
68keyblr
20+ Year Stangneter
Mar 17, 2003
946
20
49
Arizona
Dec 19, 2010
  • Dec 19, 2010
Synthetic oil has detergents that will remove old gunk that could be plugging an oil leak.
I switched my '67 vert with 115K miles to a synthetic blend without any problems.
blown65
1,938
Queen Creek Arizona
Dec 19, 2010
  • Dec 19, 2010
You could always just buy a zddp additive.
65springtime
61
Mayfield, Ky.
Dec 20, 2010
  • Dec 20, 2010
zddp? what is that? Where do you get it and what does it do? Never heard of it.
horseballz
824
Las Vegas, NV
Dec 20, 2010
  • Dec 20, 2010
ZDDP=zinc dialkyldithiophosphate is a zinc based additive/compound that helps provide anti-wear/anti-scuffing protection for engines with flat tappet cams/lifters. It has been systematically eliminated from standard motor oils, as when it burns in the combustion chamber (in worn engines) and exits, through the exhaust stream, it compromises the function/longevity of catalytic converters, providing a marginal/questionable environmental benefit while causing a truly damaging compromise of lubrication for older engines and other engines running flat tappet cams. Some suggested solutions have been to use oil formulated for diesel engines (currently still have some zddp, but may change soon) or use specialized racing oils from companies like Schaeffer, Royal Purple, Joe Gibbs, Brad Penn, etc. These racing oils will likely, eventually (if not already) be labeled "off road use only" meaning that technically you will be committing a crime by using the oil to save your engine, even though it is not environmentally harmful when no catalytic converter is involved! I believe there are also additives available over the counter to replace the zddp.
My $.02,
Gene
golf4283
1,253
Orland Park, Illinois
Dec 20, 2010
  • Dec 20, 2010
Just make sure you have absolutely no oil leaks. Even slight drips with conventional will turn into big runs with synth. I was running it in my '66 with a 5.0L and I switched back to conventional cause I was losing oil. For whatever reason Synthetic is really good at finding places to leak out of.
Hwyman
58
Bakersfield, CA
Dec 20, 2010
#10
  • Dec 20, 2010
  • #10
According to my builder, and an article he showed me from Popular Mechanics, the zinc is only necessary for initial cam/lifter break in with flat tappet lifters. Most oil has some zinc in it, but ideal for the break in is 1200ppm. Regular oil is much less than that. A bottle of the ZDDP additive (~$10), in the first start up oil should do it. Once the cam/lifters burnish the surface of each other, any quality automotive motor oil provides adequate lubrication. The article specifically recommends against diesel, motorcycle or other oils not made specifically for automotive gas engines, as they contain additives that really shouldn't go in our cars.
blown65
1,938
Queen Creek Arizona
Dec 20, 2010
#11
  • Dec 20, 2010
  • #11
Valvoline VR1 has lots of Zinc also.
mtaqua
345
#12
  • Dec 20, 2010
  • #12
don't run a flat tappet, but know people who do and have wiped a lobe after break in. Also, know those who haven't and don't run oil with zinc. The $10/per oil change, or added cost of the other brands of oil are much cheaper than a new motor (or the cost to fix one with a wiped lobe), just my 2 cents.
Wicked65
490
NORCAL
Dec 21, 2010
#13
  • Dec 21, 2010
  • #13
From what i have read, if you change your oil like you are supposed to, regular oil is fine. Unless your wanting to change oil in the 7000 mile range. But, for the cost of 1 sythetic change, you could do 2 regular changes. and if your just cruising the car, i wouldnt worry about it.
65springtime
61
Mayfield, Ky.
Dec 21, 2010
#14
  • Dec 21, 2010
  • #14
OK, appreciate all the info. I think I will stay with regular oil after reading all this. Thanks guys.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
Paint and Body help locating pony fender emblem
  • fredpinto
  • Oct 18, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 18, 2026
fredpinto
