T-45 Shift Knob fit 1979 SROD?
The 12mm size fits T-5s as far back as 1983 ...
Just not sure if they threaded the SROD handle the same ...
There is a Ford Racing tech sheet for installing a Tri-Ax here:
http://64.233.167.104/search?q=cach.../FordInstShtM-7210-N.pdf++SROD++shifter&hl=en
It suggests that the Tri-Ax bolts up to the T-5, T-45 and SROD equally well.
But, I called the Ford Racing hotline and they said that's not true. Also, I've read that SROD had a three-bolt mounting for the shifter, not the 4 bolts used on T-5 / T-45 and Tri-Ax.
Anyone know if the SROD was 12mm shift knob?
They had metric TRX wheels/tires back then ...
VGT
