t-45 Tailhousing Swap
Tailhousing
thanks for the response man. I would like to keep the Cobra Crossmember the way it is. The location (further rearward that the gt) was selected to move the cg closer to the center for better handling (or so I have read/heard)
Can this pin be reinstalled easily? My T5 in my notch needs to come out because the speedo drive gear on the output shaft moved back and now the speedo don't work. I was just gonna pull the whole trans because the shop who rebuilt it will fix that for free.
It is easy to reinstall as well. Just align the hold in the steel shift block with the hole in the shaft. Use a hammer to tap the rolled pin back in until it is flush...
