Michael Yount
Mustang Master
Sorry Jaided - don't know how I missed that. So, what's it reading, and what do you think it SHOULD be reading? Have you got someone with an accurate speedo that can time you? Whatever the % difference is, that's the % difference you need to make with a gear change.
Example. Let's say it's reading 60, but it should be reading 75. That means it's reading 25% too slow. If it has a 19 tooth in there now, then you need a 25% change in the driven gear which is like a 14 tooth. 16 is the lowest I've seen. So you can put a 16 in, and still be about 10% off; or you'll have to change the drive gear to the next highest one.
Have you checked to see what drive gear you have? If you know the % you're off, and what drive and driven gear you have, we can figure out what combo will get you there.
