T-5 conversion Experts ONLY Please
  • Thread starter Thread starter 10HoleLX
  • Start date Start date Mar 30, 2004
10HoleLX
257
Southern California
Mar 30, 2004
  • Mar 30, 2004
I did a T-5 conversion about four years ago.
Thanks to Links found here on Stangnet the job was a great success from start to finish
The only thing I didn't do on my conversion was to connect the Neautral Safety Switch
It wasn't a big deal back then but now that I want to take it to the track its become a problem because the rule book says "vehicle must have a Neutral Safety Switch in working order".
I remember I didn't install it because I couldn't find anything to connect it too!
The switch was on the pedal etc but could not find the connectore "wrapped up in a wire loom that the instructions said
I looked and looked took all the wire looms apart etc.
I gave up and have been running without it ever since.
Any links that actually tell you how to wire one up etc?
My car is a 1990 LX (build date Jan 1990)
blk92stangg
583
Hawaii
Mar 31, 2004
  • Mar 31, 2004
Eww...that's gonna be a hard one...mine were just hanging there with the jumper inserted in. If I was looking for an open plug I would have never found it myself. If I were in your situation, I think I would source an ignition kill from the parking safety switch that is now jumpered under the car ( the one that you either soldered together or used the T5 harness on. You could run the wire to the pedal and attach it there. Hope that helps.
Asha'man
1,909
Denver
Mar 31, 2004
  • Mar 31, 2004
It's taped up in the harness that's right around that area. You'll have to pull it down and then cut a little bit of tape to loosen it up, then pull the jumper out. Once you do that, just plug it into the receptor on the clutch pedal and you'll be good to go.
Ash
10HoleLX
257
Southern California
Mar 31, 2004
  • Mar 31, 2004
Hey thanks for the replies.
I try to find that jumper again Asha'man
if that fails I'll try to rig something with that parking safety switch that my auto had
Thanks!
I hope I find the jumper though.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
