T-5 From a sn95 v-6
If its cheap it may be worth trying. Find someone(such as me) who has 2.3s laying out so you can try to bolt them up while its out of the car. The pilot bearing is probably a little bigger same as the V8 usually. May need to be machined.
No it's a T-5. The T-5 is still used on V6 Mustangs and will be used on the '05 V6's.
You will need to swap the input shaft and input bearing retainer to use an SN95 T-5 on a Fox.
