t-5 question
  • Thread starter Thread starter a_turbo_stang
  • Start date Start date Apr 29, 2004
a_turbo_stang
346
Cincinnati Ohio
Apr 29, 2004
  • Apr 29, 2004
Ok I put a new bearing retainer on my t-5. And now I have this god awfull whine. Sounds like a bearing. Could the input shaft bearing be going bad? I put a new throwout bearing on and pilot bearing. Or could one of those bearings be bad? It makes the whine when it is in gear. Does not do it in nuetral. But it does it in every gear. Any help would be great.
Rick 91GT
Mustang Master
95
99
PA
Apr 29, 2004
  • Apr 29, 2004
Did you check the endplay on the imput shaft? Every retainer upgrade I have done required different shims to get it back to the .000-.002 spec for endplay.
V
v8only
2,378
22
49
Apr 29, 2004
  • Apr 29, 2004
That's a tough one. When you put the new bearing retainer in, did you swap over the inside shims from the old one??? If not, you should have used the original shims with the new bearing retainer.
a_turbo_stang
346
Cincinnati Ohio
Apr 29, 2004
  • Apr 29, 2004
yea when I bought the part from Ford They said just to use the old shims. It is a steel retainer. They told me If I put the old shims in it would be fine.
So did I fry my bearing by not checking for inplay and shimming it?
Rick 91GT
Mustang Master
95
99
PA
Apr 29, 2004
  • Apr 29, 2004
You have to check the endplay, I have had to add and subtract shims on Fords and the other aftermarkets. Remember to put some permatex around the retainer before bolting it down or the front will leak.
If the front bearing lets go it will cause a lot of damage....
a_turbo_stang
346
Cincinnati Ohio
Apr 29, 2004
  • Apr 29, 2004
How do I check for endplay? Is there a site that will explain how to do it and what tools are needed?
Thanks for the info.
Rick 91GT
Mustang Master
95
99
PA
Apr 29, 2004
  • Apr 29, 2004
You use a dial caliper with a magnetic mount, end play is how much the shaft moves in and out, it will have some play side to side.
The first thing I would do is check the fluid level on the tranny, the fill plug is the top plug on the passenger side, if you stick the small end of a allen wrench in the hole you should get fluid, if not the fluid is low and that alos causes the front bearing to whine.
a_turbo_stang
346
Cincinnati Ohio
Apr 29, 2004
  • Apr 29, 2004
So it should have some play in and out when I check for endplay? I know when I installed it, there was no play in and out.
Rick 91GT
Mustang Master
95
99
PA
Apr 30, 2004
  • Apr 30, 2004
It is near impossible to tell .002" by hand it really needs to be checked with a dial mic.
Spec is .000-.002 preferred, you do not want it preloaded or it adds stress to the imput shaft and front bearing.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
W
Electrical 91 GT Alternator Replacement Question
  • willrh111
  • Oct 22, 2025
Fox 5.0 Mustang Tech Oct 23, 2025
nickyb
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
