T-5 Questions
  • Thread starter Thread starter GSXRMIXXER
  • Start date Start date Nov 19, 2006
GSXRMIXXER
97
  • Nov 19, 2006
2 questions
1. The speedo gear= when you remove it and then replace it should you put RTV around the hole before bolting it in?
2. When you look at your transmission from inside the car should it not be centered? Mines offset to the right...?
GSXRMIXXER
97
  • Nov 20, 2006
Anyone? it's because the questions are related to a T-5 huh?
795.0pacecar
lover of pudgy polygamists
Jul 11, 2003
480
Senoia, GA
Nov 20, 2006
  • Nov 20, 2006
The speedo cable has an O-ring on it, you should not have to put RTV on anything, but if you still dont trust it it wont hurt. Yes the tranny offsets to the right a little, it does it a lot more in 79-83 mustangs originally equipped with an SROD.
GSXRMIXXER
97
  • Nov 20, 2006
Hmm...thanks. I didn't put any RTV on there because i didnt see any around the hole after i removed it however, i didn't even check the O-Ring condition. Only way to find out is to look for a leak i guess. One last stupid question...what kind of tranny fluid do you put in it? ATF?
MikeC
240
SLC, UT
Nov 20, 2006
  • Nov 20, 2006
ATF.
795.0pacecar
Jul 11, 2003
480
Senoia, GA
Nov 20, 2006
  • Nov 20, 2006
Dextron Mercon III. I hate when people just say ATF because this is not correct.
GSXRMIXXER
97
  • Nov 20, 2006
stupid question but im sure many make the mistake and use ATF.
lutzgt86-91
88
Homer IL
Nov 20, 2006
  • Nov 20, 2006
I use syncromesh in all my t5 2 3/4 quarts you can buy it at Autozone
GSXRMIXXER
97
  • Nov 20, 2006
i will try that out considering i usually shop at autozone since it's closest to my house. how much does it run per quart?
MikeC
240
SLC, UT
Nov 20, 2006
#10
  • Nov 20, 2006
  • #10
And I hate it when people call it Dextron because this is not correct, it's actually called Dexron. Just kidding with ya! You are correct, saying ATF could confuse someone into using the old Ford Type F.
Mustang78
486
Aberdeen, WA
Nov 20, 2006
#11
  • Nov 20, 2006
  • #11
what if i just use regular old ATF, not the ford type F stuff..i've been running that for months with no problems, it will grind the first couple shifts when cold tho, but not badly
~Mark~
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Nov 20, 2006
#12
  • Nov 20, 2006
  • #12
SYnchromesh is not recommended for the T-5 because it causes the paper linings in the synchros to swell. It will feel great, but the wear rate is accelerated slightly.
Mercon/D3 only
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
