  • 1994 - 1995 Specific Tech
t-5 rebuild
  • Thread starter Thread starter stprorolla49
  • Start date Start date Mar 23, 2006
stprorolla49
1,455
15
39
Fairfield, CT/North Jersey
Mar 23, 2006
  • Mar 23, 2006
before you guys jump down my throat, yes i searched this topic, and yes i read every thread....that being said, i need to rebuild my t-5 because 3rd gear grinds when i shift any faster than clicking it 1/2 way, then all the way into gear...it jsut started, and i wanna rebuild before it gets worse....also, this is my daily driver so it cant be out of comission for too long, so if i started this on a friday night, could i have teh car running again by sunday afternoon? my dad and i are very mechanically inclined, and we have the tools to do this, just never done a t-5...only a few muncie 4spds....last thing, does this kit below look like a good kit? thanks guys!
http://cgi.ebay.com/ebaymotors/T5-W...ryZ46103QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Mar 23, 2006
  • Mar 23, 2006
i would recomend the ford kit that summit sells. its more$ but you know the parts are quality (or atleast factory quality)
Gibbo97
92
Macon, GA
Mar 23, 2006
  • Mar 23, 2006
I'd say check out www.hanlonmotorsports.com - they have a video you can order that shows exactly how to rebuild a T-5 and a slew of parts to rebuild it as well.
mytight95
2,605
Dothan,Al
Mar 24, 2006
  • Mar 24, 2006
get the video, and i would go with D&D's kit.... ot the one that hanlon sells.....between a good kit, and the video you should be fine.
I have done it before but i can have mine out and in in about 6 hours....given no major snags come up.... Haven't done it in a while now though..
jason
stprorolla49
1,455
15
39
Mar 24, 2006
  • Mar 24, 2006
jason
great info man...im not worried about the rebuild, im just worried that im gonna need more parts in the middle of the proj that ill have to order
mytight95
2,605
Dothan,Al
Mar 24, 2006
  • Mar 24, 2006
if you order the rebuild kit from D&D, i know it has everything you'll need in it, minus the loctite for the case bolts. I believe there is even silicone in the package.
If you guys run into snags when you decide to do it, give me a holla and i will do what i can to help...
rough tool list
.125 punch
some sort of gear puller or a bearing puller and a press
scothc brite pads on a grinder work wonders for cleaning the case.... i also use carb cleaner to clean debris etc. from the parts you are reusing.
basic socket set
wouldn't hurt to have a couple hooks, such as that....
jason
stprorolla49
1,455
15
39
Mar 24, 2006
  • Mar 24, 2006
great info man...when i said more than i bargain for, i mean idk if im gonna be needing gears or not...i tihnk im gettin another case to rebuild thought that way my car isnt out of commision too ling...
mytight95
2,605
Dothan,Al
Mar 24, 2006
  • Mar 24, 2006
you can do it in a day with your own parts.... unless you are getting the other one for free iwould put the cash for it toward the rebuild kit etc.
putting it back together is the time consuming part(check, double check) you can tear it down in 30 min. or less.
jason
jason
stprorolla49
1,455
15
39
Mar 24, 2006
  • Mar 24, 2006
jason
jason
yea im gonna be gettin a fox body t-5 for free from a bud with the 3.35 gearset in there...it id in great shape gearwise, just occasionally grinds 2nd so im just gonna rebuild that...only thing is, i need a 94-95 input shaft and im having a hard time finding one....is this the only difference between this t-5 and a 94-95 t-5? are the speedo gear hookups and other things different on the foxes form the sn's?
mytight95
2,605
Dothan,Al
Mar 24, 2006
#10
  • Mar 24, 2006
  • #10
they are pretty close....... They all have slight differences but most will interchange....just post up if you have any issues... i am subscribed so i will help out any way i can
jason
stprorolla49
1,455
15
39
Mar 26, 2006
#11
  • Mar 26, 2006
  • #11
jason
thanks man...well i think im just gonna wait like 2 weeks til my vacation from school and rip my own trans out, and rebuild that, and put a new clutch in there...ill keep everyone posted
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
