T-5 swaps?
  • Thread starter Thread starter 93lxtwin
  • Start date Start date Jan 6, 2011
93lxtwin
37
Wilmington, NC
Jan 6, 2011
  • Jan 6, 2011
Ok I was reading another thread in the forum, talking about the A9l and A9p which is better issue. And it was mentioned that the corresponding computer should be installed depending on trans application and if the car has been swapped or not. Now my 93 lx was factory AOD. When I purchased it, it had been swapped to a T-5. Recently my computer took a dump and I had to replace it, I had an A3m, I replaced it with an A9l. So my question now is, do I need to repin anything? Or check to see if it was done already? If the car was a factory AOD, there will be some differences in the harness, correct? Thanks for all your help and wisdom guys.
HISSIN50
34
129
Jan 6, 2011
  • Jan 6, 2011
The difference is in the NSS circuit and the O2 harness.
Pin 30 on your originally AOD car might have been cut if you have an A9L or other manual trans EEC.
93lxtwin
37
Wilmington, NC
Jan 6, 2011
  • Jan 6, 2011
If it wasn't cut, do I need to cut it? Any other mods that need to be done with the a9l?
HISSIN50
34
129
Jan 6, 2011
  • Jan 6, 2011
It'd be time to check further to see if the harness was swapped already. The difference is in how the the circuit is grounded.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Jan 7, 2011
  • Jan 7, 2011
Unplug the EEC and remove the coil wire on the dizzy. Crank the engine over while checking for voltage on pin 46. If you have voltage, you need to repin the o2 harness.
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Jan 7, 2011
  • Jan 7, 2011
I need to recheck what pin that is. Pretty sire sig rtn is pin 46 but it might be 36
93lxtwin
37
Wilmington, NC
Jan 7, 2011
  • Jan 7, 2011
Thanks for all the information. Let me know if you find out which pin to check for voltage, so I can be sure the swap was done correctly. Thanks again for all of your help guys.
larrym1961
5 Year Member
Dec 18, 2010
570
36
49
Idaho Falls Id
Jan 7, 2011
  • Jan 7, 2011
pin 46 is signal return pin 36 is spark out (timing control)
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
Engine How to identify EEC-IV
  • keel
  • Aug 17, 2025
Fox 5.0 Mustang Tech Sep 1, 2025
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 21, 2026
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
  • dan50
  • Jul 18, 2026
dan50
