t-body help
It depends on your engine displacement and intended rpm range. For most guys with street driven 302s, 65-70 mm TB and 70-75mm MAF are good sizes. Try to keep the MAF about the same size or slightly bigger than the TB. In other words, a 70mm TB with a 75mm MAF would be a good setup on a hot H/C/I 302. A mild 302, maybe something with stock or slightly ported heads would be fine with a 65mm TB and 70mm MAF.
Any way you go, the factory 55mm MAF is generally considered a restriction.
