  • SN95 4.6L Mustang Tech
t/o bearing help
  • Thread starter Thread starter kolkid
  • Start date Start date Apr 11, 2005
K
kolkid
79
  • Apr 11, 2005
I have a king cobra clutch in my 97 gt and its getting kinda noisy after only a few months of install. is it possible to install a center force t/o bearing on it? will it work with a with a king cobra clutch or am i dammed to drive around with a noisy t/o bearing?!?!?!?!?
K
kolkid
79
  • Apr 11, 2005
uhh any one?
ttt
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Apr 11, 2005
  • Apr 11, 2005
the centerforce T/O bearing will fit... but i find that proper clutch adjustment will cure most throw out bearing noise... some others on here may disagree but this has worked for me no problems...
most stangs are way way too loose with the clutch cable... the T/O bearing is in constant light contact with the presure plate... thats the noise you hear it's the bearing spining with no preload at all and so after a little while it makes noise..
what i do is i adjust my clutch so the T/O has a very slight slight preload on it against the presure plate but not enought so it disengages the clutch fully... i have done this on mine and other mustangs and no T/O bearing noise at all.. i have a centerforce clutch so the presure plate is stiff if you do this with the stock plate be carefull you may disengage the clutch some..
some may tell you the T/O bearing is not supposed to have slight load aganist the cltuch but this is why they are wrong.. if it is not against the presure plate at all then you get a nasty pedal vibration.. and you will have almost no pedal free play.. so you will grind all your gears...
99 percent of mustang clutch/trans grinding problems is related too improper clutch adjustment... with the stock quadrant i had a noisy T/O bearing and my gears grinded when cold and a powershift without a slight grind was impossible... now my tranny slides in gears easy and no more problems...
plus the pedal is a little higher now and i can bang off great powershifts...
if you want too do my fix here.. you need a aftermarket clutch/presure plate thats stiffer than stock.. and a firewall adjuster/quadrant....
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Drive Shaft/Rear Diff Issue on 2014 GT
  • DudeStang
  • Jun 16, 2025
  • 2010 - 2014 Specific Tech
2K
2010 - 2014 Specific Tech Jan 21, 2026
gkomo
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
