  • 1994 - 1995 Specific Tech
t.p.s.
  • Thread starter Thread starter bill302
  • Start date Start date Dec 25, 2005
bill302
2,131
alabama,gadsden
Dec 25, 2005
  • Dec 25, 2005
what is the proper way to check the throttle position sensor are'nt you supposed to check for a certain voltage between two wires at idle and how do you make adjustments.
Guero
2,148
Dec 25, 2005
  • Dec 25, 2005
supposeably to set it at .98-.99. but I beleive final5.0 showed me an article if you set it between .60 and under 1 your fine
bill302
2,131
alabama,gadsden
Dec 25, 2005
  • Dec 25, 2005
i've checked it before but forgot voltage and wire colors, when i did it last i pierced two wires (don't remember colors) with a needle and connected a voltage meter to needles and at idle its supposed to be .something, and how do you adjust if high or low.
Guero
2,148
Dec 25, 2005
  • Dec 25, 2005
hers a how to just read everything before you start http://www.muscularmustangs.com/tps.php
drakesdad
961
Oregon OHIO
Dec 25, 2005
  • Dec 25, 2005
Good subject. I just ordered a 70 mm throttle body tonight and as I look at the thread I see that I probably will have to remove it from my old body and place it on the new. Anything I should know guys?
bill302
2,131
alabama,gadsden
Dec 25, 2005
  • Dec 25, 2005
thanks guero thats exactly what i needed.i don't know which i love the best my stang or this site.LOL
Guero
2,148
Dec 25, 2005
  • Dec 25, 2005
its gonna be a bitch to put it on. well at least for one it was.
Guero
2,148
Dec 25, 2005
  • Dec 25, 2005
never mind i was thinking about the elbow.
HISSIN50
34
129
Dec 25, 2005
  • Dec 25, 2005
Grady is right about it being able to self-zero upon closing. But if someone has a surge issue, setting it cant hurt.
Good luck.
Guero
2,148
Dec 25, 2005
#10
  • Dec 25, 2005
  • #10
so you just put a new one in and it does it by itself?
Gibbo97
92
Macon, GA
Dec 25, 2005
#11
  • Dec 25, 2005
  • #11
And I'll need those T.P.S. reports on my desk monday....
Guero
2,148
Dec 25, 2005
#12
  • Dec 25, 2005
  • #12
what?????
HISSIN50
34
129
Dec 25, 2005
#13
  • Dec 25, 2005
  • #13
Technically it should, but I would check it with a meter to see where it baselines.
Good luck.
Guero
2,148
Dec 25, 2005
#14
  • Dec 25, 2005
  • #14
ok hopefully it works. thanks
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 26, 2005
#15
  • Dec 26, 2005
  • #15
Good luck.
JT & all
Ya'll take a look at this thread
See what the guy ... runner ... has to say about this topic!
IMHO ... Factual info about this subject
http://eectuning.org/forums/viewtopic.php?t=5729&sid=062fc5c81e028e2ea0510ffc46d00643
Grady
HISSIN50
34
129
Dec 26, 2005
#16
  • Dec 26, 2005
  • #16
That is good info Grady. It is nice (I guess) that the Ford allowed for such a wide array of sig-return tolerance. We werent advising to set the sensor near a given extreme, were we? The adaptability range cuts a rather wide swath.
That info parallels that of S&2B's, et al.
Good stuff as usual Grady.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Dec 26, 2005
#17
  • Dec 26, 2005
  • #17
I totally forgot my cover sheet.
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
W
intermittent start and rough, high idle. 06 gt
  • Woe06
  • Jan 7, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jan 7, 2026
