t-rex wiring question
  • Thread starter Thread starter luckythirteen13
  • Start date Start date Oct 7, 2005
L
luckythirteen13
648
Anaheim, CA
Oct 7, 2005
  • Oct 7, 2005
i got my vortech kit used (the kit was used with a new head unit) and it didnt come with the wires for the t-rex pump. that means i have to make my own wiring. can anyone tell me what gauge wire to use?
also, its missing that plastic clip that ford uses to hold the fuel lines together, the one that looks like a little plastic horseshoe almost. what is that called and where is the best place to get one?
thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 7, 2005
  • Oct 7, 2005
Wire sizes & current ratings.
18 gauge wire = 5-8 amps
16 gauge wire = 10-12 amps
14 gauge wire = 15-17 amps
12 gauge wire = 20-25 amps
10 gauge wire = 30-40 amps
8 gauge wire = 50-60 amps.
Check the current rating on the T-Rex pump. My guess would be in the 15-17 amp range, but I do not know for sure. Use the next higher current rated wire if in doubt.
I recommend that you use a fuse wired to the battery side of the starter solenoid, just like the stock fuse links. Run your power wire from there to a relay. Use the relay to switch theT-Rex pump power on & off. Use the power lead (Brown/pink wire) from the pump side of your old fuel pump relay to one side of the new relay coil. Ground the other side of the relay coil. That way when you turn the key to run, the new fuel pump will power up & run. It will protect the stock pump & wiring from the overload that would occur if you ran both pumps off the stock wiring.
AutoZone wiring diagrams
http://www.autozone.com/servlet/UiB..._us/0900823d/80/16/71/3c/0900823d8016713c.jsp for 79-88 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/19/59/5a/0900823d8019595a.jsp for 89-93 model cars
http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-98 model cars
L
luckythirteen13
648
Anaheim, CA
Oct 7, 2005
  • Oct 7, 2005
i bought 10 gauge. the wires that are on the pump look to be 12 so im good there. i have the relay and am completely comfident about all the wiring except one part. the wire i tap into to activate the relay for the second pump. it says i have to tap into a red/purple wire but i cant find it. does anyone have a pic or a good description of where it will be. the vortech plans say its near the tail light...not very helpfull for someone not so good at wiring
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 7, 2005
  • Oct 7, 2005
The best place to tap the wire for the relay power is the pink/black wire at the fuel pump or the brown/pink wire at the inertia switch. The inertia switch is probably easier to get access to since it is under the interior plastic cover for the driver's side tail light.
Follow the diagram I posted since it is for your 92 model Mustang.
J
jabGT
59
Michigan
Oct 7, 2005
  • Oct 7, 2005
Just looked at my wiring today, the wire power wire & power ground for the T-REX are 12 AWG
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 8, 2005
  • Oct 8, 2005
In that case, use either 10 or 12 gauge wire. The larger size 10 gauge wire won't hurt anything, it is just bigger and harder to bend and hide. I would use a 20 amp inline fuse where you connect to the starter solenoid.
L
luckythirteen13
648
Anaheim, CA
Oct 8, 2005
  • Oct 8, 2005
i have 10 gauge so im good. my battery is in the trunk so im running the main power wire right from there, not going to run the wire all the way to the front of the car for no reason
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 8, 2005
  • Oct 8, 2005
That should work fine, the wiring can all be in the back of the car which would make it simpler and neater.
  • dan50
  • Jul 18, 2026
dan50
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
