T-stat housing bolt help
Dtowncats
340
York, PA
I am doing a timing chain cover gasket and in the process of putting everything back together. I am having trouble getting to the bottom bolt with a wrench. The plug for the distributor and the top water pump bolt is in the way. Is there a way to move the distributor out of the way because I don't want to have to take off the accessory bracket? Or would it just be better to take the acc. bracket off? Thanks
Along the lines of what Kevin did, it seems like an allen head bolt would work well in that location too.
I also remove it 1/64th of a turn at a time with a box end. I cant remember if a ratcheting-box-end helped or not.
Good luck.
I would tighten the bolt finger tight with needle nose pliers. There is a raised edge on the bolt, around the outer edge, I could grip that with the needle nose pliers and snug up the bolt and than use a 1/4" drive universal and appropriate socket. This procedure always worked pretty good for me.
I put allen head bolts on the thermostat housing, and use a ball end allen wrench to turn them.
Otherwise, set the engine up at TDC no 1 and just pull the dist, and put it back in later. Mark the dist location first. This should get it running and you can time it later if needed.
