T-Top weatherstripping
Prime Lord
Crappy Default Title
2,137
199
114
Denver-ish
Okay, now that 50Resto is back up....I'm about to order all new gaskets for my T-Top stang...
I'm getting this The 9-piece kit
But, what about the piece of rubber that runs down the A & B pillars? Since its a T-Top car, I'm guessing the convertable ones would work, but I'm just not sure.
These are the closest I can find..but I'm not sure which ones to get.
Clicky
Also, do these apply to the T-Top car?
Any other gaskets I need for the doors or top?
Hey man I just replaced all of mine
first off LRS-24442PR you do not need!
The 9 piece kit gives you the felts, the t-top seals, the glass seal on the t-top.
YOu have to buy regular door seals and cut them for our cars if you want to replace everything. Which in my opinion is the best way to do it.
PN = LRS-20708A-K
You run this along the bottom up to the top and cut it, it goes in behind the t-top rubber. You will see what I mean as you start to take it apart. Best advice I can give you, have a couple guys to help keep it in place while you pull and move it around to get it lined up. It was a PITA when I did it and there was two of us working on it.
Edit***
If you call they are great to doeal with and will tell you all the right part numbers you need to do a complete seal replacement ona t-top. That is what I did.
the felt strip can be a little tricky if you are replacing that I messed mine up and had to re order another kit but it makes a world of difference when done and look's great
Lucky for me, the bodyshop thats repainting the car is doing all the work :D I just have to know what stuff to order so that they can put my car back together.
Now then, contrary to the diagram on the site, the body side gaskets actually come down the A & B pillars for the front of the windows?
If thats all I need is the 9-pc kit and the door to body seals, then I'm golden. Thx.
9 Piece kit and the Regular door seals are all you need. Good luck with it all and post some pics when you get her back. Unreal what a little bit of selas does for the look of the car. It really does make the car look new again.
