T45 in a 95?
HairyCanary said:
No, the T-45 has an integral bellhousing and it will not bolt up to a 5.0. If you want something better than a T-5, get a Tremec.
so like a 3550?
every where I have read says its a 5 speed with a 5th gear overdrive.. does that mean you have one more gear after 5th? or is 5th the overdrive?
its not a 6 speed, but its five speed PLUS overdrive right? so after 5th there is one more gear for better fuel economy?
ShreddinPB said:
and oh yeah.. are all Tremec 6 speed trannys a tremec T56?
is a 6 speed tremec out of a 2000 camoro ss ls1 a t56?
Yes, it's a T-56. But it's not 100% identical to the T-56 for a Mustang, and using one is not a trivial swap.
so like a 3550? every where I have read says its a 5 speed with a 5th gear overdrive..
Yep, it's a 5-speed. 5th is the overdrive gear. For a good, strong tranny I'd get a 3550 TKO or a new TKO 600. T-56 would be cool, but it's spendy and six gears are unnecessary on a V8 in my opinion.
Dave
yeah t56s are spendy.. but there were a couple camoro ones on ebay ;)
I'll look into the TKO ones
thanks for the advice.. I am a little scared of the stock t5 3rd gear.. I had one die on me pretty bad
