T5 Conversion Report
The Fidanza comes with 2 weights, so you can run it how ever you need it 0, 28, or 50 oz. It also has a replaceable friction surface, so instead of machining it when you change your clutch, you just swap it out and it is like new again. Mine is ballaced to 50oz as my engine is built from an 88gt.
The early starters for a C4 car work perferct with this swap. No special starter is needed. I kept mine as I replaced a C4. If you are swapping for a 3 or 4 speed, you'll need the C4 style starter. I think their around $50 at your local parts store.
I used the stock shifter since I don't race the car.
