Okay, I'm without a scanner, so you will have to deal with pics, but DIRECTLY FROM MY 1983 FORD SHOP MANUAL.
Page 41 of Section 16-32 (T5 OD 5 Speed Manual Transmission)
Note under the heading Lubricant. 2.4 Liters of Dexron II Fluid.
This manual was written in 1983 BEFORE the world class transmissons came out (by 3 years). It refers to the original T5's that were used in 1983 Cars (as it was the first year for the transmission and is why it is listed in the supplement).
That transmission had Dexron II When it left Dearborn, and unless somebody changed it to the incorrect fluid (which happens a lot) it should still be using Dexron II (or an equivalent).
